Home > In Car Electronics > A question for the connector gurus.....
Can anyone help me identify the connector used for the headlamp power-wash pump on Discovery 2 and Defender vehicles (probably also RRC, D1, and many others).
It is a two pin connector generally similar to a Superseal but with what look to be 4.8mm (or possibly even 6mm) blades rather than the usual narrower Superseal inserts. The Disco 2 Electrical Library give the part number as AFU3820, but I haven't been able to link this to anything meaningful.
Any help identifying this connector would be gratefully appreciated.
The connector on the pump looks like this:-
Post #666631 24th Nov 2017 11:56am
ibexman
You need Paul Mc on ‘‘this forum PM him
Post #666632 24th Nov 2017 12:06pm
Martin
Site Admin
Looks like a wide-terminal version of the Econoseal used on the lights.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #666635 24th Nov 2017 12:10pm
It's actually quite a lot bigger than an Econoseal, more the size of a Superseal.
Post #666636 24th Nov 2017 12:13pm
Martin
Site Admin
OK I'll have a dig about for you Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #666637 24th Nov 2017 12:14pm
dorsetsmith
OK Scrub that
Post #666638 24th Nov 2017 12:22pm
Martin
Site Admin
It's not that, wrong shape  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #666639 24th Nov 2017 12:30pm
Martin
Site Admin
Have you got the pump to hand? If so can you measure across the widest part of the connector - across the "ears"  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #666640 24th Nov 2017 12:42pm
Martin
Site Admin
2015 D90 XS SW
Post #666641 24th Nov 2017 12:43pm
Not to hand, it's at home. I will measure tonight.
I have found a GM part that looks promising, but I can't find a UK supplier:-
https://www.carid.com/standard/headlight-w...-1347.html
https://www.amazon.com/ACDelco-PT1447-Orig...B000C9U1W6
Amazon.com will ship to the UK, but surely there must be something home-grown!
Post #666642 24th Nov 2017 12:48pm
Martin
Site Admin
I think I've found a match but need the dimension to confirm. Also measure the width of the metal tabs if you can Smile
Confirming if they are 4.8 or 6.3 will do, doesn't need to be exact Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #666644 24th Nov 2017 12:59pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
it looks a ford connector i had on my fiesta etc
Post #666645 24th Nov 2017 1:02pm
Thank you! Thumbs Up I will update with measurements later on.
Post #666646 24th Nov 2017 1:06pm
Looks a bit like a 2.8mm blue Superseal, which are typically higher current. WeWillWin🇬🇧🇺🇸
⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #666654 24th Nov 2017 1:27pm
Martin
Site Admin
Doubt if it's Ford as the use of the connector pre-dates their ownership of LR.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #666656 24th Nov 2017 1:54pm
