Home > Off Topic > Grumpy Old Man Thread |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
I think we should have a raised blood pressure thread after today's chasing my insurance claim.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
2nd Apr 2012 7:56pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 |
Pulling an old carpet up.....
Then treading barefoot on the grippers |
2nd Apr 2012 10:08pm |
Now that questions your position in the gene pool
2nd Apr 2012 10:14pm |
No question, I know my place |
2nd Apr 2012 10:17pm |
That'll teach you to wear steel toe-caps next time you do any work at home
2nd Apr 2012 10:28pm |
ok so here goes ... this w/e's jobs ... nothing will get done because it will either be (1) too cold (2) rain (3) snow ...
I want to finish fuse box on 110, check door pillar/roof bolts and fit an accelerator cable to the 300/tdi .. if the weather is kind, I'll probably bash my knuckles and it will go pear shaped |
5th Apr 2012 6:52am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
I thought there was a Salibury Plain trip on this weekend but must have got the dates wrong and will have to work now anyway as I have spent to long doing up the boat
Took 2 days rubbing all the boat woodwork down and half way through putting 7 coats of oil/varnish on with 24 hr drying time in between - GRUMP! But got my new wndows in Just need to finish sorting the mess the previous owner made - some people should just not do DIY - GRUMP! Trying to get her done in next two weeks for a trial sail for a five day sail/rally in May Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
5th Apr 2012 7:23am |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
Don't know much about boats but I'd fix that big hole in the back - it might help buoyancy perhaps ?
5th Apr 2012 8:22am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 |
don't know too much about boats but that hole should be there, as you can see its been deliberately cut out and I can only assume its for ballast - is the bottom half of the hull the ballast tank?
5th Apr 2012 8:28am |
na, it's to let the water out |
5th Apr 2012 11:50am |
It started life as an outboard boat then an inboard was put in so the well hole was covered over. The last owner went back to an outboard so re-cut the well badly I am half-way to sorting it out, one more layer of filler and sanding should make a neater job Then it's time to paint the hull and she is ready to go She is a well travelled boat used to sail from Scotland to France each year but I am planning to go over to the Isle of Wight for her maiden voyage... to test everything out! |
5th Apr 2012 1:01pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4733 |
Hope it is more water tight than the vehicles you usually drive 1982 88" 2.25 diesel
5th Apr 2012 8:03pm |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
Mine's watertight - once the water gets in it can't get out... Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
5th Apr 2012 8:11pm |
Boat chatter Steve.
5th Apr 2012 8:15pm |
