Home > My Defender > My Defender.....has been born & delivered |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Mine hasn't, it's got rubber ones and so did the last one? Has anyone got a photo of said leather lever etc? Thanks Boy |
14th Feb 2011 11:43am |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
Doh..... am being a prize tit Apologies - am thinking of my Td5 and the other Td5 XS's that I looked at. I'll get me coat Jon - 110 td5 [sold]. Currently Defenderless. |
14th Feb 2011 12:56pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
18Stone
For what it's worth, I had my first 110 replaced by Land Rover due to numerous bodywork issues and mechanical problems within the first month. The replacement vehicle has had a few niggles, mainly the clutch, but I am very pleased with it. Done 11,000 miles now and I am glad I stood my ground and got the original replaced. Hope your problems are sorted one way or another. Bob |
14th Feb 2011 1:03pm |
Phew!! I though Land Rover had done me again |
14th Feb 2011 1:18pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Not good, sorry to hear about all this
I wouldn't let any monkeys go anywhere my vehicle with a drill, they just don't care . Do it yourself properly the second time. I bet they won't paint the bare metal of the old holes to stop them rusting and I bet they won't seal them properly - probably just pinch a bit of dum dum from somewhere else. When they drill the new holes will they paint the metal and seal the screws......they will just start rusting otherwise The best option is always do anywork you can yourself. If you can't, make sure the dealer is a good one or find a good independent (independents are usually more contientious as they survive on their reputation, lads employed in a worskhop on a wage havn't the same motivation a lot of the time!) Hope they get it sorted but I would be rejecting it. They've messed up the A post, god knows what the noise is and what damage is being done and what more fiddling they are going to do to try and fix it. I would really not want to let someelse drive it back to the dealership, how are they going to drive - great fun new car lets burn it up..........No Thanks. Surely it should be transported back with the noise anyway. Reject it and start again with a decent one. You may have to wait but this one will probably be in the workshops for a while anyway. I would be bloody furious and looking at compensation or courtesy car for some of the waiting period until a new one arrives..... |
14th Feb 2011 4:38pm |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
genuine snorkels all fit like that sorry ...
14th Feb 2011 4:57pm |
Martyn Member Since: 10 Feb 2011 Location: Stourbridge, West Midlands Posts: 151 |
Nothing like a dealer cocking up the options, fitting the wrong ones or in the wrong place. Really takes the shine off a new motor for ya don't it?
Once it's drilled it's drilled. Hope you get your issues sorted pronto and in the meantime I'd play merry hell up matey starting with LR Customer Services. |
14th Feb 2011 5:15pm |
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 |
You mean, they all DON'T fit like that!? If that's the final position then they are shaped wrong. I despair. D300 HSE 110 |
15th Feb 2011 9:19am |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 |
Hate to read things like this. Best of luck with sorting it out......don't be afraid to reject the car if it is the right thing to do.
15th Feb 2011 10:10am |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
No Puma has leather gear knobs, the only other option is the alloy SVX ones
15th Feb 2011 10:30am |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Bad luck, but keep on at them. If they refit your RAI, they'll also be drilling two more holes so close to the old ones that they may cause a real weakness. Watch out for it. The easiest time to get them to sort stuff out is at the very start of ownership. Congratulations otherwise and really enjoy her (when they've sorted out the stuff). Perhaps make them redo the PDI properly. Certainly make an issue of ti all with LR Customer Services. They're quite good at sorting things out and are good at throwing freebies at you in compensation. |
15th Feb 2011 1:28pm |
Just clarify are these Mantec and do they really all fit like this. I suppose as long as it is sealed where it should be it's OK as maybe you wouldn't want the whole body of the snorkel resting/rubbing on your paint work! |
15th Feb 2011 1:48pm |
To clarify, I certainly do not think that the snorkels should fit like that. It's set too high and needs to rest on the wing. I'll snap ours later and post the pic.
15th Feb 2011 2:04pm |
Just spoken to Mantec who say there is a small gap....what is small, difficult to say without measuring and comparing!! They say as long as it is fitted as per instructions it will be OK.
15th Feb 2011 2:37pm |
