![]() | Home > Maintenance & Modifications > A day in the life of Miffy the 110... |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17705 ![]() ![]() ![]() |
I hope the forum gods forgive me for not being outside fixing Miffy today
![]() ![]() Click image to enlarge |
pistonfields Member Since: 29 Mar 2022 Location: Zurich Posts: 76 ![]() ![]() |
I think the fuse box looks similar to the 1530x series by EATON/Bussmann, albeit not being the same. They offer a wide variety of configurations (empty, you populate it with wires / terminals yourself and can choose setups for relais, fuses and both). Very good products and available through mouser, if anyone is looking for a good, sealed and modulare fuse box.
https://www.mouser.ch/datasheet/2/87/eaton...282271.pdf |
Key fob batteries needed changing today, cannot believe this is only the second time I have had to do this since owning the old girl.
For those who are interested the batteries are CR2032. |
Oh you know all the best things in life are those you want but do not necessarily need
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20729 ![]() ![]() |
Y’all knocked it out the park right there.
![]() I see it has on the barcode made in PRC. ![]() Is this a similar scenario as designed in GB, made in China? ![]() All the same looks some nice kit. ![]() Wants and needs, most things do need an actual purpose and manufacturers are very good at making things have a genuine purpose and not only looking good. The cable I.D. Tags are a nice touch. ![]() ⛽️🛢️⚙️🧰💪 |
Yes the ID tags are useful but only up until the point when they fall off and disappear to the depths of the wheel arch
Success....!
The adapter I needed was indeed a 3/8 male NPT to 3/8 female NPT ![]() Now it can be fitted to the LT230 extended sump drain plug. A good result. ![]() Click image to enlarge ![]() Click image to enlarge |
On to the MudStuff Mud Pod re-design...
This is how the current setup looks. The switches are about to move down to the centre dash and the Overdrive temp gauge is moving into the pod. ![]() Click image to enlarge This is the plan for the Mud Pod ![]() Click image to enlarge There will slo be a second USB-C charge post on the Riverside side of the pod for my phone holder/charger. Should work I think... The battery monitor is a TBC at the moment. |
Well the old girl has her eyes back in again. Just spent the last hour running the headlight loom where it needs to go. The result is a perfect 12.7v all the way to the JW Speaker headlights and absolutely no flickering at all, even with the engine off.
![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10946 ![]() ![]() |
It's a great feeling when it all works as it should do and Miffy's front is back to normal
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Cannot tell you Clay how great it is not to have flickering headlights anymore. So much so that I have been out this evening and tried them again in the dark
![]() ![]() Last edited by geobloke on 25th Jan 2024 9:26am. Edited 1 time in total |
Well you have to be sure, don't you . . . . . . . . .
Just had to take a few photos with Miffy yesterday/today. No other reason than I could
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
