Home > Maintenance & Modifications > A day in the life of Miffy the 110...
Page 57 of 60 <123 ... 5657 585960>
Thumbs Up
Post #1021699 18th Jan 2024 7:07pm
geobloke
I hope the forum gods forgive me for not being outside fixing Miffy today Whistle
Post #1021754 19th Jan 2024 10:26am
pistonfields
Switzerland
I think the fuse box looks similar to the 1530x series by EATON/Bussmann, albeit not being the same. They offer a wide variety of configurations (empty, you populate it with wires / terminals yourself and can choose setups for relais, fuses and both). Very good products and available through mouser, if anyone is looking for a good, sealed and modulare fuse box.
https://www.mouser.ch/datasheet/2/87/eaton...282271.pdf
Post #1021780 19th Jan 2024 3:31pm
geobloke
Key fob batteries needed changing today, cannot believe this is only the second time I have had to do this since owning the old girl.
For those who are interested the batteries are CR2032.
Post #1021907 20th Jan 2024 2:32pm
Screbble
geobloke wrote:
Ah I knew I took a photo of the box it came in here you go, made in California.
I took these the day I opened it for reference.
That’s a splendid fuse/relay box.
I don’t need one but now want to buy one Rolling with laughter
Post #1021921 20th Jan 2024 4:53pm
geobloke
Oh you know all the best things in life are those you want but do not necessarily need Rolling with laughter
Post #1021932 20th Jan 2024 6:56pm
Y’all knocked it out the park right there. Laughing
I see it has on the barcode made in PRC. Whistle
Is this a similar scenario as designed in GB, made in China? Laughing
All the same looks some nice kit. Thumbs Up
Wants and needs, most things do need an actual purpose and manufacturers are very good at making things have a genuine purpose and not only looking good.
The cable I.D. Tags are a nice touch. Thumbs Up KEEP CALM AND Drill ON
Post #1021938 20th Jan 2024 8:02pm
geobloke
Yes the ID tags are useful but only up until the point when they fall off and disappear to the depths of the wheel arch Rolling with laughter Nothing that a multimeter cannot overcome Thumbs Up
Post #1021980 21st Jan 2024 8:54am
geobloke
Success....!
The adapter I needed was indeed a 3/8 male NPT to 3/8 female NPT Thumbs Up
Now it can be fitted to the LT230 extended sump drain plug. A good result.
Post #1022300 23rd Jan 2024 4:52pm
geobloke
On to the MudStuff Mud Pod re-design...
This is how the current setup looks. The switches are about to move down to the centre dash and the Overdrive temp gauge is moving into the pod.
This is the plan for the Mud Pod
There will slo be a second USB-C charge post on the Riverside side of the pod for my phone holder/charger. Should work I think...
The battery monitor is a TBC at the moment.
Post #1022302 23rd Jan 2024 4:57pm
geobloke
Well the old girl has her eyes back in again. Just spent the last hour running the headlight loom where it needs to go. The result is a perfect 12.7v all the way to the JW Speaker headlights and absolutely no flickering at all, even with the engine off.
Thumbs Up Thumbs Up
Post #1022396 24th Jan 2024 4:47pm
L110CDL
It's a great feeling when it all works as it should do and Miffy's front is back to normal Thumbs Up Clayton.
Keeper.
Post #1022426 24th Jan 2024 9:07pm
geobloke
Cannot tell you Clay how great it is not to have flickering headlights anymore. So much so that I have been out this evening and tried them again in the dark Rolling with laughter Rolling with laughter
Post #1022431 24th Jan 2024 9:50pm
L110CDL
Well you have to be sure, don't you . . . . . . . . . Whistle Clayton.
Keeper.
Post #1022434 24th Jan 2024 10:23pm
geobloke
Just had to take a few photos with Miffy yesterday/today. No other reason than I could Rolling Eyes
Post #1023228 1st Feb 2024 2:52pm
