Home > Maintenance & Modifications > Steering wheel
Page 3 of 4 <1234>
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I think I'm probably going to be looking at the optimill boss as it appears to be the thinest or slimest. Now its a question of which steering wheel? 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #596789 27th Jan 2017 6:24pm
Froglaise
Me too I think. They direct fit all Momo, I've just emailed to see if they fit Raid/Startech as now I've held a Startech in my hand I can't consider anything else Shocked
Post #596798 27th Jan 2017 6:43pm
Chris90V8
England 1987 Defender 90 2.5 TD XS CSW Portofino Red
Hi all...
Been watching this thread with interest and today phoned optimill with an order for a 36 spline quick realease boss.
Optimill was very friendly and professional, informed that my order will be sent out today (2nd class - sign for)
£154.98 with postage...
Will post a pick when fitted Thumbs Up
Cheers.... Chris ðŸšœ. ...... . .... . .. 🚗ðŸšðŸš›ðŸššðŸššðŸš—🚙ðŸš
Post #596799 27th Jan 2017 6:45pm
JOW240725
Just seen this comment from Optimill on FB with reference to their quick release boss being used on a standard wheel
James Bolland "No it isn't compatible with the standard wheel, only MOMO style wheels but we have just developed an adaptor to fit mota lita wheels too"
Thought might be relevant/of interest. James
Instagram @suffolk_rovers
Post #596843 27th Jan 2017 8:54pm
300TDi CSW Phil
Sorry if my original post misled. I do not plan on fitting the original steering wheel on a quick release boss.
What I would like to achieve is a quick release boss and new steering wheel which are in as close to the original steering wheel position as possible. Lots of the combinations look like they bring the wheel considerably closer to the driver which is exactly what I am not trying to do. 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #596888 27th Jan 2017 11:22pm
300TDi CSW Phil
It's decided......
It's going to be an Optimil QR boss as I like the look of its dimensions and they appear to be a highly rated company producing good products.
The next question is what to fit I know it can't take a Startech and my budget wouldn't stretch to that anyway so I'm looking for a sensible Momo, OMP, Sparco etc 70x6 PCD suggestions.
Alternatively does anyone know what the PCD is on the Exmoor trim MK1 leather steering wheel? It looks like it comes with its own boss but not QR. 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #597076 28th Jan 2017 8:37pm
stephan123
Hello again,
Thank you all for your tips/advice.
Pulled the trigger on the Optimill QR boss and Momo jet steering wheel and here is the result (wheels weren't straight when pic was taken!)
Very easy to do, big improvement to driving experience, nice to have more cabin space and removable wheel provides great security feature.
Thoroughly recommended upgrade!
Post #599050 4th Feb 2017 1:51pm
Froglaise
Looks nice Thumbs Up
Is that the 320mm or 350mm version of the wheel?
Post #599068 4th Feb 2017 4:04pm
300TDi CSW Phil
My 48 spline Optimill boss turned up yesterday so it is time to tidy up my steering column (fit a new shroud etc since the last one came off for a replacement indicator stalk it squeeked when it went back and came off again). Then my new boss and MOMO Tuner will be going on.
Once done I will post a pic or two. 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #599069 4th Feb 2017 4:12pm
300TDi CSW Phil
I said I would post some pictures once I had changed it so here goes:
Old original wheel (covered as disinegrating) and absence of column shroud.
Old wheel and new MOMO Tuner (350mm) next to each other
New wheel and column shroud fitted
Wheel removed for the night showing Boss in place and new shroud.
Am I happy.......... you bet Thumbs Up 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #599097 4th Feb 2017 6:59pm
X4SKP
Hello stephan123 and 300TDi CSW Phil
Well done both, they look good, and soon it will be second nature to remove your wheel
before walking away.
I near enough always remove mine now, whilst this should only be considered as 1 level
of security, it is in my opinion, a good one.
One extra step, now you have this, consider turning the road wheels when parking...
thinking about if pushed where the vehicle would move to... Shocked
towards the curb... Thumbs Up
not into an open space... Thumbs Up
not out of the garage... Thumbs Up
Without the Steering Wheel and with effort, the Road Wheels can be straightened or
pointed where desired, if there is attempt to steel your Defender, the Steering Lock,
if functional could join in, and may help to slow things down, it's the time / annoyance
factor you are trying to move in your favor.
Every little may help... SKIP
Post #599104 4th Feb 2017 7:37pm
stephan123
Thank you X4SKP for the additional security tips! Froglaise my Momo is 350 mm
Post #599225 5th Feb 2017 1:37pm
300TDi CSW Phil
Just discovered one downside of a removeable steering wheel.
Parked up car (on driveway) took wheel indoors and put safely down side of sofa...... roll on 16hrs.
Go to get steering wheel from side of sofa .... it's not there.
Ask who has seen it and get blank responses. Go into other room to discover 3 year old twins sat in little chairs thanking me for their toy car and pretending to drive around the room Rolling with laughter 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #599499 6th Feb 2017 10:29am
JOW240725
Good update on wheels!!
And Defender immobilised by 3yo twins!! Rolling with laughter Rolling with laughter James
Post #599549 6th Feb 2017 1:37pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
If I were you I´d lock the wheel in the car to keep it safe from the little ones. Rolling Eyes 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT´s,
Recaro CS´s, anorak, wellingtons
Post #599552 6th Feb 2017 1:51pm
Page 3 of 4 <1234>
