Home > Puma (Tdci) > How can I lower the Tow Ball
Page 2 of 2 <12
Dixon Bate and Bradley (which was by then part of DB) were taken over by ALKO last year, as I found out when I tried to get spares for a Bradley hydraulic-damped ex-military trailer coupling.
Sadly it seems that in the course of the take over everyone who knew anything about Bradley or DB products left the company! The people who responded to my enquiries initially denied that the coupling existed, then denied it was made by Bradley, and then when confronted with photographic evidence of both its existence and a makers plate, serial number, NSN, etc simply said they knew nothing about these couplings and didn't support them.
It was not a good customer experience and disappointed me considerably! Big Cry
Post #595830 24th Jan 2017 9:37am
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
Thanks guys that gives me a few choices.
Not quite made up my mind which one to get but will need to buy it soon.
Post #596201 25th Jan 2017 4:25pm
Gary Parnell
Pjb can you let me know the make of your towball you have on your nas step please
Post #767804 9th Apr 2019 9:54am
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Westfalia.
The bolt holes I have used in the photo below are approximately 83mm width and 55mm vertical. It fitted my Masai rear step (spacing 90mm/56mm) without modification, as the bolts thinner than the bore of the step holes. The rear spreader plate needed a slight chamfer on one edge, as the Masai step holes are slightly higher than the OEM step. I'm in the process of moving it from the Masai step on the 110 to the OEM step on the 90; I'll post up the finished ball height once it's refitted.
 Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #767938 9th Apr 2019 11:09pm
Gary Parnell
👌thank you
Post #767946 10th Apr 2019 5:38am
leeds
Westfalia were the inventors of the towball for cars.
The Nakatanenga dropped towball is made by Westfallia and is available in the UK here
Please note that if fitting this to a non genuine NAS step that the back plate may need altering. Different aftermarket manufacturers of NAS steps use varying different methods of strengthening/bracing the middle of their NAS steps
HTH
Brendan
Post #767968 10th Apr 2019 8:07am
Page 2 of 2 <12
