Home > Puma (Tdci) > How can I lower the Tow Ball |
Crofter Member Since: 19 Feb 2015 Location: Peterhead Posts: 169 |
Thanks guys that gives me a few choices.
Not quite made up my mind which one to get but will need to buy it soon. |
25th Jan 2017 4:25pm |
Gary Parnell Member Since: 07 Apr 2019 Location: Oxfordshire Posts: 9 |
Pjb can you let me know the make of your towball you have on your nas step please
9th Apr 2019 9:54am |
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 495 |
Westfalia.
The bolt holes I have used in the photo below are approximately 83mm width and 55mm vertical. It fitted my Masai rear step (spacing 90mm/56mm) without modification, as the bolts thinner than the bore of the step holes. The rear spreader plate needed a slight chamfer on one edge, as the Masai step holes are slightly higher than the OEM step. I'm in the process of moving it from the Masai step on the 110 to the OEM step on the 90; I'll post up the finished ball height once it's refitted. Click image to enlarge Current Steeds: 2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale Last edited by doublea on 10th Apr 2019 1:34pm. Edited 2 times in total |
9th Apr 2019 11:09pm |
👌thank you
10th Apr 2019 5:38am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Westfalia were the inventors of the towball for cars.
The Nakatanenga dropped towball is made by Westfallia and is available in the UK here Please note that if fitting this to a non genuine NAS step that the back plate may need altering. Different aftermarket manufacturers of NAS steps use varying different methods of strengthening/bracing the middle of their NAS steps HTH Brendan |
10th Apr 2019 8:07am |
