Home > Puma (Tdci) > How can I lower the Tow Ball
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
I often tow my caravan with my Defender (Puma). The caravan is higher at the tow ball than at the rear. I am a bit worried about damaging my caravan on say a sleeping police man etc. I cannot see on the net how to lower the tow ball.
Any of you guys found what to buy to get over this problem
Post #595546 23rd Jan 2017 11:48am
nick345345
Scotland 2012 Defender 110 Puma 2.2 USW Baltic Blue
I had a similar problem with my 110 and trailer. I've fitted an adjustable tow bar (LR007222) which is quite a lot lower than the fixed towbar I had before and the twin axle trailer now uses both axles....
Post #595547 23rd Jan 2017 11:55am
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Dixon Bates adjustable.
the best there is
Clemmo Thumbs Up Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #595548 23rd Jan 2017 12:01pm
Martin
Site Admin
Have a search on here for "Dixon Bate" - plenty of people use their slider system to lower the tow ball height.
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #595550 23rd Jan 2017 12:02pm
pjb
I bought attached from Brendan as had the same problem, but I had a NAS rear step so may not work for you
Couple of different height options Thumbs Up
Tows perfectly level 2020 P300 HSE
Post #595555 23rd Jan 2017 12:16pm
JOW240725
Dixon Bate Thumbs Up
 James
Instagram @suffolk_rovers
Post #595558 23rd Jan 2017 12:33pm
miker
I have a long dixon bate ladder bolted on in a similar manner to JOW. My defender is either lifted or has HD springs (Not sure which!) and the towball sat way too high for the twin axle Ifor I use.
Now it sits pretty much level when empty and slightly nose down when loaded. Overrun brakes are far more effective when it's not trying to push up into the hitch as well!
Post #595568 23rd Jan 2017 1:20pm
TJ101
4 diferent trailers,, 3 different hights
As above, best option California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #595575 23rd Jan 2017 1:37pm
IanW
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
What's the situation with drop plates for the tow ball? Apparently Witter are ok with a drop plate on a Disco or Defender with their towbars. My 110 has a standard LR towbar from new. Various other forums suggest that some 4x4s have some kind of exemptions from the type approval requirements when a drop plate is fitted - does this apply to the standard LR fitment? It seems that to be type approved the process has to include testing with a drop plate. All a bit confusing. I've got a drop plate in the garage, and the caravan does ride a bit high at the front - but don't want to do anything unsafe/illegal. One wife - livid
Post #595615 23rd Jan 2017 4:06pm
miker
As far as i understand it, flat plate drop plates are questionable/illegal/not type approved. I would feel comfortable using one unless horrendously over engineered, the loads generated when towing are considerable, and it wouldn't be that hard to bend a standard 10mm drop plate.
Post #595616 23rd Jan 2017 4:16pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Had a similar problem to sort out, on my 90 with 50mm higher springs. I tow a number of trailers including a 3.5 ton dual axle trailer, which doesn´t make the 90´s life easy, if it is not level.
Using a 90mm extended tow ball from Thule (Sweden), the top of the ball is 46 cm high, without any load on it, which works perfectly for me. It drops to about 43 cm with the big trailer hitched up. With a lighter 2200 kg flatbed trailer, it works well, too.
With a max nose weight of 200 Kg, and D-value of 20 Nm, it is well suited to the Defender.
The Thule part number is 530072.
Couldn´t find you a UK supplier, but this is where I purchased mine (in Germany).
https://www.kupplung.de/universal-kugelkopf-4-loch-122042.html
Stephen
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT´s,
Recaro CS´s, anorak, wellingtons
Post #595671 23rd Jan 2017 7:44pm
shipbadger
United Kingdom 2011 Defender 110 Puma 2.4 HCPU Galway Green
Always used the Series type drop plate. This is a shallow U shape and much less likely to buckle than the flat plate which LR introduced with the first 110 models. This tended to buckle under when farmers trailers of unknown weight were attached. The standard response by garages around here was to revert to the Series type, which is still available.
Tony Comber
Alwa
Post #595673 23rd Jan 2017 7:58pm
leeds
The law about towing equipment is quite straight forward however applied to Defenders not so straight forward.
Cars since about 1997 need type approved towing equipment.
Commercial vehicles do not require type approved towing equipment.
Commercial Defenders such as hard tops are classified as commercial so do not need type approved towing equipment Some Defender SW need type approved towing equipment
Since about 2012 ALL Defenders were classified as commercial so no need for type approved towing equipment (Sorry can not remember exact year! Am sure someone will supply correct year)
So it depends if your Defender is M1 or N1 tax class. Banging Head Banging Head
Tow ball height? EEC directive 94/20/EC says towball height fully laden should be between 350 and 420mm
Caravan/trailer hitch height should be between 385 and 455 mm
Good info here
Dixon Bates towing equipment is type approved. OEM suppliers of towing equipment to Land Rover.
The Nakatanenga drop tow ball available HERE is E marked.
Please note if you want a larger fuel tank and/or tank guard it may impinge on fitting towing equipment.
A 2" receiver and drop plate is not type approved. Legal on commercial Defenders. We have lowed on 2" receivers with no issues.
HTH
Brendan
Post #595715 23rd Jan 2017 9:28pm
xtr2turbo
United Kingdom 2016 Defender 110 Puma 2.2 USW Corris Grey
Wild Card 90 wrote:
That is the neatest drop tow ball I have seen. Thanks
David
Post #595727 23rd Jan 2017 9:59pm
IanW
Thanks for these responses. I've got an enquiry in with Dixon Bate and will post the response. Interesting to note that Dixon Bate and AlKo are in the same premises by the look of it, as the caravan has a twin axle AlKo chassis the response ought to be specific. Without hunting for the reg document the 110 tax is a bit over £500, so M1 I guess. One wife - livid
Post #595828 24th Jan 2017 10:29am
