Home > Puma (Tdci) > CAUTION! PUMA & fording
Page 5 of 7 <1234567>
Glynparry25
Lorryman100 wrote:
How about fitting this Glyn. Whistle
That is who makes it Cool. I have seen these before but cant be bothered paying £300 for something I could make with 2 titanium pins, 4 washers and 4 R clips. The roll bar wouldn't be on often- more for the trips back to UK once maybe twice a year Thumbs Up..... then again with that frequency I might just take it off/ put it on when I want to.
Glyn Dog Sheep
Post #56158 2nd Feb 2011 7:13am
BigMike
Or have a word with Gwyn, get him to machine one of his sumo bars and then make quick release brackets.
this might be of interest too, but Gwyn also says that Pumas NEED a wading kit if in water of any depth, but that the gearbox breather is tricky due to its location.
Post #56189 2nd Feb 2011 10:45am
Naks
Yep, tried to get that extended, but you can only get there by dropping the gearbox.
Post #56214 2nd Feb 2011 2:02pm
fordy103
2010 Defender 90 Puma 2.4 HT Zermatt Silver
my gearbox breather comes up into the engine bay with the other ones? had this discussion before with a few people.. Mike ive got my car booked in at that place in preston to get my suspension fitted, ill ask his opinion?
cause i rang mantec and they said pumas didnt need a wading kit unless your going to windscreen height??
Post #56687 4th Feb 2011 11:39am
Naks
There are 3 breather pipes that terminate into the engine bay, how many do you have?
Post #56845 5th Feb 2011 6:46am
fordy103
i have 3, was assuming one was front axle, transfer box, and gearbox? who knows ?
Post #57090 6th Feb 2011 10:45am
Naks
I also have 3. Myself and the mechanic traced all to the front diff, back diff and transfer box. The gearbox one terminates somewhere on the bellhousing, so to extend it to the engine bay involves dropping the gearbox Confused
Post #57098 6th Feb 2011 11:40am
spudfan
Ireland
I have four-the extra one is the extended breather from the fuel tank.An extended breather for the gearbox would seem like a sensible thing to have. Pity the boys at Solihull did not do it for us. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #57103 6th Feb 2011 12:14pm
spudfan
Ireland
Would it be possible to reach it by removing the floor panels? 1982 88" 2.25 diesel
Post #57108 6th Feb 2011 12:44pm
MK
Actually you need to remove the gearbox cover. Puma 110" SW
Post #57116 6th Feb 2011 1:10pm
fordy103
how would you go about removing the gearbox cover then?
Post #57152 6th Feb 2011 3:22pm
MK
You need to remove the carpet or whatever you have then the gearshift knob, rubber gaiter and about 10 screws. You will have plenty of room to grab the breather pipe. Just pull it from the bellhouse (not from the gearbox!). I posted a pic some weeks ago where you can spot the pipe. Puma 110" SW
Post #57155 6th Feb 2011 3:41pm
Anderzander
fordy103 wrote:
well if you look at standard props from a TD5, and then a puma, the joints are bigger on a puma, had a look today on a Td5 in tescos! LOL
If it was Monaco Blue, like the one in my avatar, it was probably mine!
Post #57862 8th Feb 2011 10:53pm
BigMike
Ander, I see you have a gatesgarth video. We have permits for May Thumbs Up
Where in lancs are you?
Post #57867 8th Feb 2011 11:06pm
Anderzander
Hi Mike
I'm between Preston and Blackpool - near Elswick. Whereabouts are you?
I love Gatescarth, I try and drive it every year. I'm down for June this year.
Fancy meeting to say hello?
Stephen
Post #57871 8th Feb 2011 11:13pm
