Home > Puma (Tdci) > CAUTION! PUMA & fording |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
That is who makes it . I have seen these before but cant be bothered paying £300 for something I could make with 2 titanium pins, 4 washers and 4 R clips. The roll bar wouldn't be on often- more for the trips back to UK once maybe twice a year ..... then again with that frequency I might just take it off/ put it on when I want to. Glyn |
2nd Feb 2011 7:13am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 |
Yep, tried to get that extended, but you can only get there by dropping the gearbox. |
2nd Feb 2011 2:02pm |
fordy103 Member Since: 22 Dec 2010 Location: preston lancs Posts: 85 |
my gearbox breather comes up into the engine bay with the other ones? had this discussion before with a few people.. Mike ive got my car booked in at that place in preston to get my suspension fitted, ill ask his opinion?
cause i rang mantec and they said pumas didnt need a wading kit unless your going to windscreen height?? |
4th Feb 2011 11:39am |
There are 3 breather pipes that terminate into the engine bay, how many do you have? |
5th Feb 2011 6:46am |
i have 3, was assuming one was front axle, transfer box, and gearbox? who knows ?
6th Feb 2011 10:45am |
I also have 3. Myself and the mechanic traced all to the front diff, back diff and transfer box. The gearbox one terminates somewhere on the bellhousing, so to extend it to the engine bay involves dropping the gearbox |
6th Feb 2011 11:40am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4731 |
I have four-the extra one is the extended breather from the fuel tank.An extended breather for the gearbox would seem like a sensible thing to have. Pity the boys at Solihull did not do it for us. 1982 88" 2.25 diesel
6th Feb 2011 12:14pm |
Would it be possible to reach it by removing the floor panels? 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
6th Feb 2011 12:44pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2447 |
Actually you need to remove the gearbox cover. Puma 110" SW
6th Feb 2011 1:10pm |
how would you go about removing the gearbox cover then?
6th Feb 2011 3:22pm |
You need to remove the carpet or whatever you have then the gearshift knob, rubber gaiter and about 10 screws. You will have plenty of room to grab the breather pipe. Just pull it from the bellhouse (not from the gearbox!). I posted a pic some weeks ago where you can spot the pipe. Puma 110" SW
6th Feb 2011 3:41pm |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 |
If it was Monaco Blue, like the one in my avatar, it was probably mine! |
8th Feb 2011 10:53pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Ander, I see you have a gatesgarth video. We have permits for May
Where in lancs are you? |
8th Feb 2011 11:06pm |
Hi Mike
I'm between Preston and Blackpool - near Elswick. Whereabouts are you? I love Gatescarth, I try and drive it every year. I'm down for June this year. Fancy meeting to say hello? Stephen |
8th Feb 2011 11:13pm |
