![]() | Home > Puma (Tdci) > CAUTION! PUMA & fording |
fordy103 Member Since: 22 Dec 2010 Location: preston lancs Posts: 85 ![]() ![]() |
just to clarify the ecu is mounted at the top of the bulkhead behind the engine?
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
YEP ![]() Glyn ![]() |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
On a personal note when you do any decent wading there is a small chance you may get in a few inches deeper than you expect (having walked the route with a stick first of course
![]() Couple of thoughts - check air tightness of snorkel by covering it up and stalling the engine, and; if you have ARB lockers with externally fitted compressor then you may want to fit a pipe to the compressor inlet too. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2663 ![]() ![]() ![]() |
Difficult on a Puma, no? |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
On a Td5 you can stall the engine by putting the hand on the snorkel, done this a lot of times while testing airtightness on fresh installed snorkels....
...on the first Puma it nearly broke my hand! WANTED: SII or SIII in max 1.5k |
How do u make a snorkel airtight? |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5078 ![]() ![]() ![]() |
Remember even if you go deeper than the top of the bonnet the water underneath remains much lower unless you stop (yes there is splashing)
Personally I don't think beyond the height point in the bonnet...never had any other need in any other LR Mike |
we produce 3 different types of 100% waterproof snorkels. 1 each Tdi, Td5 or Puma.
A standard LR or Mantec snorkel is hard to get airtight but with a lot of silicone and GAFFA Tape do a pretty good job. WANTED: SII or SIII in max 1.5k |
AndrewS did a post on how to seal the Mantec snorkel.
Basically as nakatanenga said - lots of sealant and gaffa ![]() If you want to do a really thorough job, you need to take the pipework out from the airbox to the snorkel and replace it. If you look at the D4x4 forum, they're doing a post (referenced here somewhere too) on a no-holds barred expedition upgrade on a Defender. They fit a Mantec but properly seal it. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
For a proper snorkel - its safari all the way Mike
Yep Safari for me too.
BTW - I get the point made by Mike that the bow wave under the bonnet should produce a lower wave than the front of the car BUT - what if you have to stop or reverse out, you can't keep a constant speed or you hit a large underwater object that slows you down? £10 of plastic pipe and a Saturady morning means that I can choose to go across a ford (ie not a nice tarmac'd road) with some confidence in the knowledge that the only thing saving my diff/gearbox from getting water in it is forward speed and luck. At the end of the day we all make choices - and some of them are personal - so can't argue with that - based on intended use. Me, well I may go slighly over the top in some areas - but where I'm planning to go there is no AA |
Norfolk? ![]() |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 ![]() ![]() ![]() |
You can ford a Puma without a snorkel - just can be a bit 'brown trouserish'
![]() Engine was fine but the carpets were sodden ![]() ![]() Click image to enlarge John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
SJM Member Since: 09 Dec 2007 Location: Kent Posts: 237 ![]() ![]() |
Great photo
![]() '11 Defender 110XS Utility SW '07 Discovery 3 HSE '58 Porsche 356A (not good off road) '59 Lambretta (not good on or off road!) |
