Home > Puma (Tdci) > CAUTION! PUMA & fording
Page 1 of 7 1234567>
nakatanenga
Germany
on the PUMA the gearbox breather is NO LONGER in the engine bay! it is just some some cm over the bellhousing!
So if you go fording take care to raise all breathers and air intakes..... WANTED:
SII or SIII in max 1.5k
Post #53853 19th Jan 2011 12:48pm
mse
What model year are you talking
Mine were - but LR had not refitted them properly after a new clutch so i had to relocate them Mike
Post #53856 19th Jan 2011 12:55pm
nakatanenga
Germany
130 late 2009
About 5cm over the bellhousing! I was shocked. WANTED:
Post #53858 19th Jan 2011 1:05pm
Glynparry25
Cheers for the heads-up Peter, will check mine today.
Did you get my email?
Glyn Sheep
Post #53860 19th Jan 2011 1:07pm
nakatanenga
Germany
Yes! will answer soon....busybusybusy WANTED:
Post #53861 19th Jan 2011 1:08pm
mse
nakatanenga wrote:
130 late 2009
Mines earlier i wonder if they shrunk it! Mike
Post #53868 19th Jan 2011 1:37pm
Glynparry25
Cheers Thumbs Up
Glyn Sheep
Post #53870 19th Jan 2011 1:42pm
totoD110
thanks for the heads up... if facing from the rear. which side of bell housing was it located? TIA
Post #54057 20th Jan 2011 2:24am
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
im a nube with Defenders still, where is the bell housing?
Post #54115 20th Jan 2011 2:13pm
I have 3 plastic tubes popping up near the back of the engine bay .. not checked the rear yet.. will post photo later
Post #54132 20th Jan 2011 3:11pm
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
The bellhousing is the funnel or bell shaped bit at the engine end of the gearbox, wherein the clutch lives.
Craig
Post #54135 20th Jan 2011 3:55pm
Landie Boy
Craig
Thanks Craig Smile
Post #54253 20th Jan 2011 10:33pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Re: CAUTION! PUMA & fording
...I read somewhere, long before I bought my 110, that in the Puma there was no need do raise the breathers of the diffs and gearbox ... it was taken care off Question
And when I bought the snorkel there was no breathers kit like my TD5 used to have ... I was told there was no need for it ... Question Question Question Is it ? Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #54326 21st Jan 2011 10:36am
Naks
I'm spending next week Friday at my local indie's workshop and we will re-route all breathers to the engine bay. Being retrenched has it's benefits it seems Whistle
Post #54343 21st Jan 2011 12:00pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
I had Devon 4x4 fit axle and gearbox breathers when I had the snorkel fitted. The breathers run up the outside of the snorkel.
The major parts have to breathe somehow otherwise expanding oils will be forced past oil seals and potentially cause damage/leaks
Post #54440 21st Jan 2011 8:27pm
