Home > Td5 > Doors not latching |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2108 |
My passenger door appears to suffer with the temperature RoddyK05 - I thought it was just me
My wife (the main user of said door) said that it only happens when the temperature drops and I think she's right. Both my striker plates are relatively new (and have the nylon bush in tact) and they close perfectly in the warmer weather I look forward to reading any suggested remedies |
8th Nov 2016 11:14pm |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 |
I found the answer to this and Geobloke did a nice write up over on Land Rover UK Forums:-
http://forum.landrovernet.com/content.php/...How-to-Fix Probably worth making this a sticky as it's such a common problem as we approach colder climes... Dave Green Goddess - 1998 Defender 110 300tdi |
8th Nov 2016 11:26pm |
Good man Dave and thank you
I shall look at that over the weekend and report back if I cure it! If it works I'll claim all the credit with the missus Cheers, Will |
8th Nov 2016 11:40pm |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
Fantastic, I'll be giving that a go at the weekend - although I would have said mines were pretty clean, but a proper clean and re-grease can't do any harm at all. Here's hoping.
8th Nov 2016 11:41pm |
it work door new seal will not latch good clean as per Geobloke write up and you shut the door from inside too
9th Nov 2016 4:19pm |
Don't forget the last instruction - it's the most important one Dave Green Goddess - 1998 Defender 110 300tdi |
9th Nov 2016 5:27pm |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Desperately need to do this to mine too - my passenger door no longer closes! 2005 Td5 | 90 Station Wagon | Tonga Green
9th Nov 2016 5:32pm |
Well spank my ass and call me Charlie!
It worked a treat after a few minutes work as described by nosnibod and geobloke Next time you're up this way, you will be treated to a pint |
9th Nov 2016 7:54pm |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 |
I'll be giving this a go as the cold weather door gremlins have started. |
9th Nov 2016 9:16pm |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 333 |
Try X Engineering replacement latches. The useless/soon damaged nylon bush is gone and the latch is much less likely to rip your jeans or trousers!
http://foundry4x4.co.uk/index.php?route=pr...duct_id=68 Adjustment is easy and my 110 TD5 doors now close with a gentle push! |
13th Nov 2016 2:13am |
Just done mine. Completely bunged up with accumulated spray grease, dirt, dust, dog hair etc. Now clean as a whistle. I lubricated them again with PTFE dry lubricant in the hope they won't accumulate the grime again as quickly, but we shall see. Certainly sound a lot better and passenger door now seems to be closing, so will see how it goes over the coming weeks. Thanks to nosnibod and Geobloke for the advice 2005 Td5 | 90 Station Wagon | Tonga Green
13th Nov 2016 12:58pm |
Done mine today
Well that was a nice easy job to do,but very satisfying. Doors all looking a lot better now. Just followed the instructions. Thanks for the link Nosibod |
13th Nov 2016 4:57pm |
Down to Halfords today for brake cleaner and white scooshy grease. Done in no time, it seems to be better but I await a drop in the temperature again for the acid test. It can't fail to have made a difference, hopefully that's it for a while. As others have said, thanks a lot for the link, it shows just how good forums like this are when people need a wee helping hand.
13th Nov 2016 7:39pm |
mactheknife Member Since: 08 Jul 2016 Location: Somerset Posts: 51 |
Same issue here. Strange its always the passenger side!
Brake cleaner does the trick. |
13th Nov 2016 11:57pm |
