![]() | Home > Td5 > Doors not latching |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 ![]() ![]() ![]() |
Using pictures that a took from the web, showing the mechanism: ![]() I've sprayed the brakecleaner inside this opening in all directions. So also upward. This seems to help the most as the actual mechanism sits above the catch. ![]() Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
