Home > Td5 > Doors not latching
Page 1 of 4 1234>
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Doors not latching
With the first snows of winter, or autumn upon us and the temperature dropping, I have re discovered a wee problem I had last year. As the temperature drops, I have noticed that both my doors no longer close as easily as when the weather is more temperate. They need a deliberate push close to stop them from popping open onto the first bit of the catch. If I 'slam' them they pop open, if I hold the door as it closes I have more chance of it staying put. Anyone else got this problem, and even better - has anyone fixed it?? Is it seals, lubrication in the catches or something else? Watching eagerly for remedies Thumbs Up
Post #576413 8th Nov 2016 11:03pm
Screbble
My passenger door appears to suffer with the temperature RoddyK05 - I thought it was just me Neutral
My wife (the main user of said door) said that it only happens when the temperature drops and I think she's right.
Both my striker plates are relatively new (and have the nylon bush in tact) and they close perfectly in the warmer weather Confused
I look forward to reading any suggested remedies
Post #576416 8th Nov 2016 11:14pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
I found the answer to this and Geobloke did a nice write up over on Land Rover UK Forums:-
http://forum.landrovernet.com/content.php/...How-to-Fix
Probably worth making this a sticky as it's such a common problem as we approach colder climes... Dave
Green Goddess - 1998 Defender 110 300tdi
Post #576419 8th Nov 2016 11:26pm
Screbble
Good man Dave and thank you Thumbs Up Bow down
I shall look at that over the weekend and report back if I cure it!
If it works I'll claim all the credit with the missus Whistle
Cheers,
Will
Post #576423 8th Nov 2016 11:40pm
RoddyK05
Fantastic, I'll be giving that a go at the weekend - although I would have said mines were pretty clean, but a proper clean and re-grease can't do any harm at all. Here's hoping. Bow down
Post #576424 8th Nov 2016 11:41pm
dorsetsmith
Thumbs Up it work door new seal will not latch good clean as per Geobloke write up and you shut the door from inside too
Post #576546 9th Nov 2016 4:19pm
nosnibod
Thumbs Up
Don't forget the last instruction - it's the most important one Whistle Laughing Dave
Post #576560 9th Nov 2016 5:27pm
Green Machine
Desperately need to do this to mine too - my passenger door no longer closes! 2005 Td5 | 90 Station Wagon | Tonga Green
Post #576561 9th Nov 2016 5:32pm
Screbble
Well spank my ass and call me Charlie!
It worked a treat after a few minutes work as described by nosnibod and geobloke Bow down
Next time you're up this way, you will be treated to a pint Thumbs Up
Post #576602 9th Nov 2016 7:54pm
Martin 01
I'll be giving this a go as the cold weather door gremlins have started. Thumbs Up
Post #576636 9th Nov 2016 9:16pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
Try X Engineering replacement latches. The useless/soon damaged nylon bush is gone and the latch is much less likely to rip your jeans or trousers!
http://foundry4x4.co.uk/index.php?route=pr...duct_id=68
Adjustment is easy and my 110 TD5 doors now close with a gentle push!
Post #577441 13th Nov 2016 2:13am
Green Machine
Just done mine. Completely bunged up with accumulated spray grease, dirt, dust, dog hair etc. Now clean as a whistle. I lubricated them again with PTFE dry lubricant in the hope they won't accumulate the grime again as quickly, but we shall see. Certainly sound a lot better and passenger door now seems to be closing, so will see how it goes over the coming weeks. Thanks to nosnibod and Geobloke for the advice Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #577483 13th Nov 2016 12:58pm
Martin 01
Done mine today Very Happy
Well that was a nice easy job to do,but very satisfying.
Doors all looking a lot better now.
Just followed the instructions.
Thanks for the link Nosibod Thumbs Up
Post #577524 13th Nov 2016 4:57pm
RoddyK05
Down to Halfords today for brake cleaner and white scooshy grease. Done in no time, it seems to be better but I await a drop in the temperature again for the acid test. It can't fail to have made a difference, hopefully that's it for a while. As others have said, thanks a lot for the link, it shows just how good forums like this are when people need a wee helping hand. Thumbs Up Thumbs Up Thumbs Up
Post #577580 13th Nov 2016 7:39pm
mactheknife
United Kingdom 2004 Defender 110 2.5 TD CSW Baltic Blue
Same issue here. Strange its always the passenger side!
Brake cleaner does the trick.
Post #577684 13th Nov 2016 11:57pm
Page 1 of 4 1234>
