![]() | Home > Puma (Tdci) > Scangauge Question |
I have a Scangauge II plugged in but to do so I had to disconnect the OBD socket from it's holder in the fuse bay below the steering wheel, and feed it into the Speaker bay alongside to plu the Scangauge plug in as you cannot close the Fuse bay cover otherwise.
I want to make a new plug using the pcb board from another OBD plug, but am unable to determine which coloured wires go to which pins as the wires on the original Scangauge lead are embedded in resin. Does anyone have a wiring diagram for the Scangauge lead that shows which colour goes to which pin on the OBD Plug?? Any help much appreciated ![]() ![]() This would allow the OBD socket to remain in it's proper position, the New plug could then be easily removed when the Land Rover Dealer has to plug in to the Diagnostics to update software etc: |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
Wasn't there a post on the tech section?
Also why run it through the speaker why not through the other side? Mike |
Check out this post as shax is making up a how to pdf file
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Because the only place you can get access to it is through the speaker side ![]() |
Firstly, to mse, it doesn't matter which side you run it through, if using the original scangauge plug then you have to re-locate the OBD socket if you want the Fuse cover to close.
Secondly, to Lorryman100, I had seen that thread and was waiting for any developments as regards Shax's pdf file, but his PC problems don't seem to have been resolved, and I have all the bits ready and was itching to have a go. Cut the plastic cover off the Scangauge plug today and found the wires embedded in a resin block and cannot see which ones are soldered to which pin. Just wondered if anyone had done a similar job and would know the colour coding/pin number. |
![]() I did buy an additional cable so I could cut it and do exactly what shax did, but did not bother once i found his post. And after reading your comment about the resin block I'm glad I didnt ![]() ![]() |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
I haven't seen the other post but I am guessing you are trying to make it so that the Scangauge doesn't take up the only OBD port therefore having to take the speaker out every time?
If so: http://www.obdspy.co.uk/cables/J1962M_spliter.php If not....... ![]() Glyn ![]() |
Cheers Glyn,
just ordered one thanks ![]() ![]() |
Thanks Glyn,
Have also ordered the splitter cable. I also had a second cable for the Scangauge - useful for using the gauge on another vehicle without having to remove the original wiring each time. Anyway. Problem now solved thanks to Glyn. ![]() ![]() |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 ![]() ![]() ![]() |
Very useful indeed
![]() Thanks Glyn. ![]() Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 ![]() ![]() |
take care with that cable !
if both devices write to the ECU itīs not gonna be good so make sure u disconnect the other one or make sure 1 is a read only device ! Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
Scangauge is Read-Only, and anyway you can disconnect the lead from the back of the Display so the lead is not connected. That enables the Land Rover dealer to connect his Diagnostic computer easily, without the problem of having to remove the Speaker to disconnect the Scangauge OBD plug from the vehicles OBD socket, in case the Dealer has problems finding the socket in it's new position.
My turbogauge can erease faults : therefore it can send something to the ecu I guess Discovery 4 SDV6 Landmark
