Home > Puma (Tdci) > Scangauge Question
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Scangauge Question
I have a Scangauge II plugged in but to do so I had to disconnect the OBD socket from it's holder in the fuse bay below the steering wheel, and feed it into the Speaker bay alongside to plu the Scangauge plug in as you cannot close the Fuse bay cover otherwise.
I want to make a new plug using the pcb board from another OBD plug, but am unable to determine which coloured wires go to which pins as the wires on the original Scangauge lead are embedded in resin. Does anyone have a wiring diagram for the Scangauge lead that shows which colour goes to which pin on the OBD Plug??
Any help much appreciated Thumbs Up Thumbs Up
This would allow the OBD socket to remain in it's proper position, the New plug could then be easily removed when the Land Rover Dealer has to plug in to the Diagnostics to update software etc:
Post #51086 4th Jan 2011 9:49pm
mse
Wasn't there a post on the tech section?
Also why run it through the speaker why not through the other side? Mike
Post #51090 4th Jan 2011 9:55pm
Lorryman100
Check out this post as shax is making up a how to pdf file Bow down
Post #51091 4th Jan 2011 9:55pm
Lorryman100
Meant to say that all I did was feed the cable down behind the dash fit the obd plug then undo the torx screw and push the socket and plug into the fusebox. Put the cover back on and it only bulges slightly. Only pain is that the screw has to go back in before unplugging the scangauge to allow the nanocom to be plugged in Rolling Eyes
Post #51097 4th Jan 2011 10:05pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Because the only place you can get access to it is through the speaker side Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #51098 4th Jan 2011 10:07pm
WelshGas
Firstly, to mse, it doesn't matter which side you run it through, if using the original scangauge plug then you have to re-locate the OBD socket if you want the Fuse cover to close.
Secondly, to Lorryman100, I had seen that thread and was waiting for any developments as regards Shax's pdf file, but his PC problems don't seem to have been resolved, and I have all the bits ready and was itching to have a go. Cut the plastic cover off the Scangauge plug today and found the wires embedded in a resin block and cannot see which ones are soldered to which pin. Just wondered if anyone had done a similar job and would know the colour coding/pin number.
Post #51099 4th Jan 2011 10:09pm
Lorryman100
Thumbs Up
I did buy an additional cable so I could cut it and do exactly what shax did, but did not bother once i found his post. And after reading your comment about the resin block I'm glad I didnt Smile Anybody interested in a spare scanguage cable Whistle
Post #51104 4th Jan 2011 10:16pm
Glynparry25
I haven't seen the other post but I am guessing you are trying to make it so that the Scangauge doesn't take up the only OBD port therefore having to take the speaker out every time?
If so:
http://www.obdspy.co.uk/cables/J1962M_spliter.php
If not....... Ner Ner
Glyn Sheep
Post #51107 4th Jan 2011 10:21pm
Lorryman100
Cheers Glyn,
just ordered one thanks Thumbs Up Annoying thing is when I bought the scanguage i asked by email if they could supply a splitter as well Banging Head
Post #51109 4th Jan 2011 10:28pm
WelshGas
Thanks Glyn,
Have also ordered the splitter cable. I also had a second cable for the Scangauge - useful for using the gauge on another vehicle without having to remove the original wiring each time.
Anyway. Problem now solved thanks to Glyn. Bow down Thumbs Up
Post #51123 5th Jan 2011 6:30am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Very useful indeed Mr. Green
Thanks Glyn. Thumbs Up Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #51148 5th Jan 2011 11:34am
Alexke
Belgium
take care with that cable !
if both devices write to the ECU itīs not gonna be good
so make sure u disconnect the other one or make sure 1 is a read only device ! Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #51161 5th Jan 2011 2:39pm
WelshGas
Scangauge is Read-Only, and anyway you can disconnect the lead from the back of the Display so the lead is not connected. That enables the Land Rover dealer to connect his Diagnostic computer easily, without the problem of having to remove the Speaker to disconnect the Scangauge OBD plug from the vehicles OBD socket, in case the Dealer has problems finding the socket in it's new position.
Post #51197 5th Jan 2011 6:38pm
Alexke
Belgium
My turbogauge can erease faults : therefore it can send something to the ecu I guess Discovery 4 SDV6 Landmark
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #51272 5th Jan 2011 11:12pm
