Home > Td5 > TD5 Wipers stay on.
Saley
United Kingdom 2009 Defender 110 Puma 2.4 CSW Bronze Green
TD5 Wipers stay on.
    I have 2000 TD5 and wipers come on with ignition and will not turn off. Have tried another switch unit on steering column with no success. Have removed fuse and wired in a switch as a temporary measure. Any suggestions please.
    Post #567199 27th Sep 2016 11:32pm
    Fatboy Slim
    Wales
    Park switch on the motor is worn out Thumbs Up
    Post #567224 28th Sep 2016 7:15am
    roel
    Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
    I think this is a strange one. The park switch will normally make it stop directly after switching the wipers off so the wipers don't go to the parking position.
    I might be the park switch but It would be my first guess. I think it is a wire problem if you already changed the switch unit.
    But I could be wrong and it isn't the first time. Twisted Evil Roel
    1984 90 2.5 na Diesel - RR V8 (1994-2001)
    1997 Camel Trophy Discovery 300TDI (2001-2009)
    2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
    2003 90 Td5 (2009-now)
    Post #567230 28th Sep 2016 7:30am
    I have seen this happen with a failed park switch in the past, the contacts which drive the motor to the park position after the stalk switch has been set to 'off' are failing to open, so the 'park' feed is permanently live.
    If the plastic cam follower peg that is pushed by the cam on the gearwheel to open the contacts has worn excessively it can cause this effect, or if the contacts themselves are faulty, or the switch is simply full of crud.
    Post #567237 28th Sep 2016 8:10am
    roel
    OK learnt something again. Thumbs Up Roel
    Post #567257 28th Sep 2016 9:09am
    Fatboy Slim
    Wales
    Laughing we change them like socks. Very common problem.
    Post #567286 28th Sep 2016 11:30am
    Tommo
    United Kingdom 2006 Defender 90 Td5 Black LE Java Black
    Yip...just had mine replaced Whistle
    Post #567408 28th Sep 2016 6:36pm
    ajps72
    2001 Defender 110 Td5 SW Chawton White
    I have a similar problem with mine it starts and turns off in a random position, the timed position works likes it on.
    My problem started when someone disconected all the wires behind the switch and then "try" to connect them in the right position. Augusto
    Defender 110 TD5 2001
    Discovery 4 TDV6
    Post #567438 28th Sep 2016 8:27pm
    Saley
    TD5 wipers stay on
    Thanks guys I appreciate your comments. Will check the park switch out.
    Post #567449 28th Sep 2016 9:02pm
