![]() | Home > Td5 > TD5 Wipers stay on. |
Saley Member Since: 27 Sep 2016 Location: Cornwall Posts: 5 ![]() ![]() ![]() |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Park switch on the motor is worn out
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17716 ![]() ![]() ![]() |
I have seen this happen with a failed park switch in the past, the contacts which drive the motor to the park position after the stalk switch has been set to 'off' are failing to open, so the 'park' feed is permanently live.
If the plastic cam follower peg that is pushed by the cam on the gearwheel to open the contacts has worn excessively it can cause this effect, or if the contacts themselves are faulty, or the switch is simply full of crud. |
OK learnt something again.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
Yip...just had mine replaced
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 ![]() ![]() |
I have a similar problem with mine it starts and turns off in a random position, the timed position works likes it on.
My problem started when someone disconected all the wires behind the switch and then "try" to connect them in the right position. Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
Thanks guys I appreciate your comments. Will check the park switch out.
