![]() | Home > Maintenance & Modifications > Main beam cable location |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20745 ![]() ![]() |
Can't comment on relay but if pretty sure it's blue with white tracer.
Be sure to check though. ![]() ⛽️🛢️⚙️🧰💪 |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
Yup, blue with white in my TD5
Unless they updated it for the puma, there are no relays, all the current runs through the switch. Which is why it fails! |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
easiest location to tap into it I found was in the engine bay, left hand side, next to the bulkhead there is quite a large plug, and like others have said there is no relay and the wire colour is blue with white trace.
You can always disconnect the plug and check with a milti-meter though. |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 ![]() ![]() ![]() |
This is the linky I used: http://www.defender2.net/forum/topic11570....ght+wiring
In conjunction with the instructions from Land Rover for the standard kit...which I put in my gallery here: https://www.defender2.net/gallery/albums/u...ctions.pdf Basically (as Roy & Miker say)...most people splice into the wire under the bonnet. Here: ![]() and here: ![]() Note: The LR kit shows taking the main beam feed from near the stalk in the steering column... But doing it under the bonnet seems much easier ![]() Thanks "The Boy" (who I have not seen posting on here for ages) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
I did mine behind the headlight, really it identical make much difference as to where.
