Home > Maintenance & Modifications > Main beam cable location
Franspuma
Wales 2010 Defender 110 Puma 2.4 XS CSW Aintree Green
Hi does anyone know the relay and colour of the wire for the main beam as I'm trying to locate it within the cab to connect to the relay for my new spots. Very Happy
Post #565220 19th Sep 2016 9:32pm
Can't comment on relay but if pretty sure it's blue with white tracer.
Be sure to check though. Idea WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #565224 19th Sep 2016 9:36pm
miker
Yup, blue with white in my TD5
Unless they updated it for the puma, there are no relays, all the current runs through the switch. Which is why it fails!
Post #565258 20th Sep 2016 12:37am
Roy5695
easiest location to tap into it I found was in the engine bay, left hand side, next to the bulkhead there is quite a large plug, and like others have said there is no relay and the wire colour is blue with white trace.
You can always disconnect the plug and check with a milti-meter though.
Post #565274 20th Sep 2016 7:30am
MartinK
This is the linky I used: http://www.defender2.net/forum/topic11570....ght+wiring
In conjunction with the instructions from Land Rover for the standard kit...which I put in my gallery here:
https://www.defender2.net/gallery/albums/u...ctions.pdf
Basically (as Roy & Miker say)...most people splice into the wire under the bonnet. Here:
and here:
Note: The LR kit shows taking the main beam feed from near the stalk in the steering column... But doing it under the bonnet seems much easier Thumbs Up
Thanks "The Boy" (who I have not seen posting on here for ages)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #565277 20th Sep 2016 7:59am
I did mine behind the headlight, really it identical make much difference as to where. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #565314 20th Sep 2016 10:41am
