Home > Maintenance & Modifications > 110 d/c harsh ride
sc70
Wales 2015 Defender 90 Puma 2.2 CSW Santorini Black
110 d/c harsh ride
Have a 110 d/c puma and find the ride very bumpy when empty, dont carry anything much just do a lot of towing and with the trailer on the ride is great, so do i put 100kg in the back or is there a softer spring i could use. Have tried the search but it all seem to be spring lifts
Post #41775 2nd Oct 2010 2:11pm
Grockle
it will be harsh thats how they are when empty. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #41777 2nd Oct 2010 2:54pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
although i have a 90 i have been experiencing a harsh ride as well.
i was looking at changing springs and dampers but my local Indie suggested just change the dampers 1st because they can be very harsh.
i have put new dampers on [Tuffbacks] and i am now experimenting with the tyre pressures.
the ride is sooooo much better with the replacement dampers, it might be worth a try, also check your tyre pressures.
on the 90 i have kept to the recommended 30 at the front and as i never [ very rarely anyway!] carry a heavy load i have dropped the rears from the recommended 38 to 36, 34, 32 & 30 to see what rides best.
38 is too hard
30 & 32 caused tyre wall bounce after hitting bumps
36 seemed OK but i think the overall best ride is best with 34 so i will keep it for a week or so and see how we go.
no idea what tyre pressures you need in the DC but the above might help.
cheers BM52
Post #41782 2nd Oct 2010 4:32pm
discocuzzy
DC has heavy duty springs on the rear You cannot teach stupid people to do clever things
Post #41783 2nd Oct 2010 4:33pm
sc70
are the rear spring from a 110 SW softer?
Post #41790 2nd Oct 2010 6:36pm
BigRuss
My Td5 DC had heavy duty suspension but my USW hasn't and is a much softer ride. Russell
2011MY 110 XS USW Black
Post #41792 2nd Oct 2010 6:59pm
discocuzzy
I believe so, not sold as a work horse like the double cab You cannot teach stupid people to do clever things
Post #41797 2nd Oct 2010 9:03pm
BigRuss
I believe that the rear springs on a DC are designed for the load bed of the DC to support a 1000Kg load! Russell
Post #41798 2nd Oct 2010 9:06pm
sc70
Thumbs Up thanks for the replys
Post #41802 2nd Oct 2010 9:52pm
G4sweep
Germany 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
BigRuss, i thought all USW had HD rear springs for the reason of being able to carry 1000kgs? I'm new to the puma USW so don't know, just for some reason thought as above?
Sweep Sweep
2.2 110 XS SW
Gone;
08 D3 XS
BN55 WPV G4 4.4V8 D3.
O7 G4 Mongolian Recce 110 USW
Post #41810 3rd Oct 2010 8:53am
BigRuss
Sweep
Sweep, I am like yourself new the the puma (gave it a one month old wash yesterday) but that was the impression I was give by my dealer. By almeans please correct me if I have been miss lead but is defenatly a softer ride than my DC. Russell
Post #41814 3rd Oct 2010 9:44am
Michael S
United Kingdom 2009 Defender 110 Puma 2.4 USW Tonga Green
I used to drive (and still have in fleet!) 110 Td5 DC and the ride is firmer than Puma USW I drive now. The DC has no anti roll bars but corners at least as flat as the USW.
Michael
Post #41818 3rd Oct 2010 12:34pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
i find that a ton of sand in the back makes the ride a lot more comfortable and its cheap. Smile
Post #41827 3rd Oct 2010 1:15pm
discocuzzy
Put a roof rack and a rooftent on....sorted Thumbs Up
I changed the dampers for terra firmas and Censored part hd springs...fine when loaded but lost all my fillings without all the kit....miss her mind Thumbs Up You cannot teach stupid people to do clever things
Post #41841 3rd Oct 2010 6:43pm
sc70
OK here's my findings but they dont seem correct so if any one else can shed some light Thumbs Up
Puma 110D/C springs part no RKB500300 w/g/g stripe,
no spring weight listed on any forum i can find or with my local idependant or with Devon 4x4.
Local steeler part department has emailed L/R and their reply is, Rear sping is 72kg newton meter.
Acording to my calcs useing google the spring rate is 637lbs Shocked which i cant belive, i was expecting somthing between 300lbs and 400lbs
Have double checked figure with L/R steeler and they have confirmed 72kg n/m.
am i missing somthing Confused Confused (only spring related answers please) Thumbs Up
Post #42265 8th Oct 2010 6:20pm
