![]() | Home > Maintenance & Modifications > 110 d/c harsh ride |
it will be harsh thats how they are when empty. 2.4 90 XS
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
although i have a 90 i have been experiencing a harsh ride as well.
i was looking at changing springs and dampers but my local Indie suggested just change the dampers 1st because they can be very harsh. i have put new dampers on [Tuffbacks] and i am now experimenting with the tyre pressures. the ride is sooooo much better with the replacement dampers, it might be worth a try, also check your tyre pressures. on the 90 i have kept to the recommended 30 at the front and as i never [ very rarely anyway!] carry a heavy load i have dropped the rears from the recommended 38 to 36, 34, 32 & 30 to see what rides best. 38 is too hard 30 & 32 caused tyre wall bounce after hitting bumps 36 seemed OK but i think the overall best ride is best with 34 so i will keep it for a week or so and see how we go. no idea what tyre pressures you need in the DC but the above might help. cheers BM52 |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
DC has heavy duty springs on the rear You cannot teach stupid people to do clever things
sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261 ![]() ![]() ![]() |
are the rear spring from a 110 SW softer?
My Td5 DC had heavy duty suspension but my USW hasn't and is a much softer ride. Russell
2011MY 110 XS USW Black |
I believe so, not sold as a work horse like the double cab You cannot teach stupid people to do clever things |
I believe that the rear springs on a DC are designed for the load bed of the DC to support a 1000Kg load! Russell
G4sweep Member Since: 24 Sep 2010 Location: Paderborn Posts: 182 ![]() ![]() ![]() |
BigRuss, i thought all USW had HD rear springs for the reason of being able to carry 1000kgs? I'm new to the puma USW so don't know, just for some reason thought as above?
Sweep Sweep 2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
Sweep, I am like yourself new the the puma (gave it a one month old wash yesterday) but that was the impression I was give by my dealer. By almeans please correct me if I have been miss lead but is defenatly a softer ride than my DC. Russell 2011MY 110 XS USW Black |
Michael S Member Since: 12 Jan 2010 Location: In an Essex field Posts: 21 ![]() ![]() ![]() |
I used to drive (and still have in fleet!) 110 Td5 DC and the ride is firmer than Puma USW I drive now. The DC has no anti roll bars but corners at least as flat as the USW.
Michael |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
i find that a ton of sand in the back makes the ride a lot more comfortable and its cheap.
Put a roof rack and a rooftent on....sorted
![]() ![]() I changed the dampers for terra firmas and ![]() ![]() |
OK here's my findings but they dont seem correct so if any one else can shed some light
![]() Puma 110D/C springs part no RKB500300 w/g/g stripe, no spring weight listed on any forum i can find or with my local idependant or with Devon 4x4. Local steeler part department has emailed L/R and their reply is, Rear sping is 72kg newton meter. Acording to my calcs useing google the spring rate is 637lbs ![]() Have double checked figure with L/R steeler and they have confirmed 72kg n/m. am i missing somthing ![]() ![]() ![]() |
