Home > Maintenance & Modifications > Door seal adhesive?
110SEB
Door seal adhesive?
What do people recommend to use to reattach door seals to the door frames? Driver and passenger door seals are sagging at the top.
Post #40057 7th Sep 2010 1:39pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Contact adhesive works best, allows a bit of time to move things around too.
Post #40062 7th Sep 2010 2:01pm
mse
New seal - or make the contact better... Mike
Post #40092 7th Sep 2010 6:19pm
K9F
The seals have a metal band/thread contained within the manufacturing process! As Mse iimplied careful manipulation with a long piece of wood and pressure on a flat surface they can be made to grip again! You shouldn't really need to use any sealant or adhesive to get them to remain in position!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #40098 7th Sep 2010 7:24pm
mse
Thumbs Up
You could obviously motivate your fingers to type more Very Happy Thumbs Up Mike
Post #40114 7th Sep 2010 8:54pm
K9F
Doesn't matter how big the keys or keyboard it is always 'single digit typing' for me! Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #40126 7th Sep 2010 10:19pm
wyvern
[quote="K9F"]Doesn't matter how big the keys or keyboard it is always 'single digit typing' for me! quote]
sounds like RSI to me..! better watch out for upper limb dissorders .. Whistle Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #40132 7th Sep 2010 10:49pm
The Boy
Re: Door seal adhesive?
Hi SEB
I assume it's the top one right? Both my fronts have done the same. on mine you can see where the original glue was and was only applied in places. I have bought some spray contact glue and it is on the "jobs to do" list but for now I just thump them back home.
Boy
Post #40153 8th Sep 2010 11:03am
BigRuss
I work with a guy who removed his door seals and then applied some denzo tape before putting the seal back in place.
Post #40166 8th Sep 2010 1:25pm
dgardel
Italy
The Boy wrote:
Hi SEB
Boy
Could you post photos???? Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #40167 8th Sep 2010 1:31pm
The Boy
dgardel wrote:
The Boy wrote:
Hi SEB
Boy
Give me a hour I will sneak out the office.
Post #40168 8th Sep 2010 1:41pm
The Boy
If you can see there is parts that have none of the (original) glue on.
When this happens I just thump the seal back on.
Boy
Post #40170 8th Sep 2010 1:52pm
harveyg77
My drivers door seal did the same thing, took it back to a LR dealer and they fitted a new seal under warranty.
HTH< Harvey
Post #40181 8th Sep 2010 4:41pm
Eduardo
Same problem here, fitted by the dealers using new seal and a stronger adhesive. Until now, working OK.
Cheers! Eduardo
Post #40183 8th Sep 2010 4:53pm
BigRuss
I had both the driver and passanger door seals replaced under warrenty because of this, then later out of warrenty I just stuck them in place. Thumbs Up
Post #40194 8th Sep 2010 6:40pm
