![]() | Home > Maintenance & Modifications > Door seal adhesive? |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
Contact adhesive works best, allows a bit of time to move things around too.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
New seal - or make the contact better... Mike
The seals have a metal band/thread contained within the manufacturing process! As Mse iimplied careful manipulation with a long piece of wood and pressure on a flat surface they can be made to grip again! You shouldn't really need to use any sealant or adhesive to get them to remain in position!
![]() Treat every day as if it is your last....one day you will be right!! |
You could obviously motivate your fingers to type more ![]() ![]() |
Doesn't matter how big the keys or keyboard it is always 'single digit typing' for me!
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2118 ![]() ![]() ![]() |
[quote="K9F"]Doesn't matter how big the keys or keyboard it is always 'single digit typing' for me! quote]
sounds like RSI to me..! better watch out for upper limb dissorders .. ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
Hi SEB I assume it's the top one right? Both my fronts have done the same. on mine you can see where the original glue was and was only applied in places. I have bought some spray contact glue and it is on the "jobs to do" list but for now I just thump them back home. Boy |
I work with a guy who removed his door seals and then applied some denzo tape before putting the seal back in place.
Could you post photos???? ![]() ![]() IID Pro MV License |
Give me a hour I will sneak out the office. |
![]() If you can see there is parts that have none of the (original) glue on. ![]() When this happens I just thump the seal back on. ![]() Boy |
harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309 ![]() ![]() |
My drivers door seal did the same thing, took it back to a LR dealer and they fitted a new seal under warranty.
HTH< Harvey |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Same problem here, fitted by the dealers using new seal and a stronger adhesive. Until now, working OK.
Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
I had both the driver and passanger door seals replaced under warrenty because of this, then later out of warrenty I just stuck them in place.
