Home > Maintenance & Modifications > Door seal adhesive? |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 |
Contact adhesive works best, allows a bit of time to move things around too.
7th Sep 2010 1:01pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
New seal - or make the contact better... Mike
7th Sep 2010 5:19pm |
The seals have a metal band/thread contained within the manufacturing process! As Mse iimplied careful manipulation with a long piece of wood and pressure on a flat surface they can be made to grip again! You shouldn't really need to use any sealant or adhesive to get them to remain in position!
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Sep 2010 6:24pm |
You could obviously motivate your fingers to type more Mike |
7th Sep 2010 7:54pm |
Doesn't matter how big the keys or keyboard it is always 'single digit typing' for me! If you go through life with your head in the sand....all people will see is an ar5e!!
7th Sep 2010 9:19pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2105 |
[quote="K9F"]Doesn't matter how big the keys or keyboard it is always 'single digit typing' for me! quote]
sounds like RSI to me..! better watch out for upper limb dissorders .. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
7th Sep 2010 9:49pm |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Hi SEB I assume it's the top one right? Both my fronts have done the same. on mine you can see where the original glue was and was only applied in places. I have bought some spray contact glue and it is on the "jobs to do" list but for now I just thump them back home. Boy |
8th Sep 2010 10:03am |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
I work with a guy who removed his door seals and then applied some denzo tape before putting the seal back in place.
8th Sep 2010 12:25pm |
Could you post photos???? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
8th Sep 2010 12:31pm |
Give me a hour I will sneak out the office. |
8th Sep 2010 12:41pm |
If you can see there is parts that have none of the (original) glue on. When this happens I just thump the seal back on. Boy |
8th Sep 2010 12:52pm |
harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309 |
My drivers door seal did the same thing, took it back to a LR dealer and they fitted a new seal under warranty.
HTH< Harvey |
8th Sep 2010 3:41pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
Same problem here, fitted by the dealers using new seal and a stronger adhesive. Until now, working OK.
Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
8th Sep 2010 3:53pm |
I had both the driver and passanger door seals replaced under warrenty because of this, then later out of warrenty I just stuck them in place.
8th Sep 2010 5:40pm |
