Home > Maintenance & Modifications > Door seal adhesive? |
I recently took the drivers side seal off to facilitate removal of the pillar trim for routing a new wire. I was surprised how much drill swarf dropped out of the headliner on seal removal. My seal wasn't glued at all and went back on a treat. Maybe on build they have a mastic gun on standby just in case??? If you go through life with your head in the sand....all people will see is an ar5e!!
8th Sep 2010 6:12pm |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 |
My dealer crimped mine back into position with a special tool. No problems since. 130 crew cab
98 V8 Disco |
8th Sep 2010 6:32pm |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Will do mate
Might get round to it on Saturday |
9th Sep 2010 8:14pm |
I used this as extra sealing on my Snorkel....Worked a treat, is clear and should do the job you require it to...
http://nextday.diy.com/app/jsp/product/pro...ctId=92565 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
9th Sep 2010 8:23pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Thats what i used Mal worked fine door seal still inplace NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
9th Sep 2010 8:24pm |
Does what is says on the tin! (Well tube actually)
The Works! It is obviously fit for exactly that purpose then as Fekete states... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
9th Sep 2010 8:28pm |
