![]() | Home > My Defender > Corris 110.... |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2940 ![]() ![]() |
Painted my surrounds and prepared the rear cubby...
![]() Click image to enlarge After I test fit, it will be off for a re trim. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Been putting off this job but took my time and got a perfect fit all around.
A rough cut to start and then just used the dremel to bring it in to shape. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Subframe nearly ready to test fit.
![]() Click image to enlarge Rear electric windows should all be in place tomorrow evening. Started the sound proofing tonight, using Skinz, and also adding a 10mm Skinz lining kit on the roof. Badly want everything back togther now but still have a load of wiring to add... ![]() Also decided to add the alpine digital TV tuner, but i am going to add an external rack antena. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10946 ![]() ![]() |
Looking good Andy
![]() Clayton |
New gears made up for the disco motors...
![]() Click image to enlarge With the door in pieces and glass tied up out of the road I fitted Skinz over the complete inner door. ![]() Click image to enlarge Disco motor now with new gear and plenty of lube fixed in place and worked perfectly first time, i drove it off the front motor cables for a while to get the benefit of a strong voltage. ![]() Click image to enlarge And the door card all back on ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
So when can we place orders for the kit?
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
After 1000 cycles....
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
I do enjoy looking in on your thread. So many wonderful mods that donīt come straight out of the box. Inspiring stuff.
![]() 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
A right pain to do but hope it's all worth it, added the Skinz to the roof and then the Skinz 10mm foam...
Then had to get all the cables in for the overhead player, a lot of wiring! I have some coming down each door A post and then the TV/PS4 heading to the back, just wasn't enough room. It is ones of those jobs that you need 4 arms, I ended up using the bottle Jack to hold it in place! Hopefully the rest will be straight forward. The biggest pain was the rear view mirror re fitting. No matter what I tried it would not go back on.... Then suddenly realised I just needed to unscrew the mounting place and fix it on top on the headlining, clicked back on in seconds then... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
All back in place after some tweaks. Biggest pain was forgetting to put the back section of the head lining in first so have to take it all down and start again
![]() ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Connections made up front now and all cables neatly run.... I just need to connect up the power now and fingers crossed. Also doing a clean up in the battery box now and adding an ignition sense module which will make it handy for connecting this and the rear electric
Andy, with those two pictures above, I think I would need a button like below installed somewhere in my truck. Courageous man.
![]() ![]() Eric ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Lol, I was going to take to compete dash out but I have to do the school run in the morning Andy
