Home > Maintenance & Modifications > Outside temperature
Page 1 of 4 1234>
holdingpoint
Italy 2008 Defender 90 Puma 2.4 SW Stornoway Grey
Outside temperature
Hi guys
I am wondering if is possible to find a reliable outside thermometer for my Defender, in the past I bought some thermometers but I found no ones precise.
I also wondering if is possible to connect a thermometer to the ECU, I'am pretty sure that ECU does has an outside temperature sensor, may be is possible to connect the output data to the central electronic display of TD4, Isn't it the same electronic display of freelander? If is possible we can change our display on defender with a freelander one?
Post #39887 5th Sep 2010 5:26pm
AndrewS
I have one of these
http://www.maplin.co.uk/Module.aspx?ModuleNo=34745 130's have feeling's as well you know Smile
Post #39892 5th Sep 2010 6:14pm
holdingpoint
Ok, well, thanks Andrew, but I though about something less invasive, and more "automotive". I have to ask to the dealer where the freelander's indicator is connected, and if is connected to the ECU.
Post #39927 6th Sep 2010 8:45am
dgardel
Italy
Like mine?
You can buy it here
http://www.speedup.it/index.php?locale=en&...me.1131211
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #39939 6th Sep 2010 10:13am
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
very nice dgardel,
have you any photo with your outside sensor? tnks www.newfoundland.gr
Post #39950 6th Sep 2010 12:21pm
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
http://cgi.ebay.co.uk/LCD-Digital-Thermome...925wt_1139
Any good?[/url] My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #39955 6th Sep 2010 1:06pm
shingwell
The engine knows the air intake temperature, and a Scanguage can display this.
While you are moving it should be the same as the outside air temperature, although if you have been stationary with a hot engine there is little new air coming in and the reading rises, falling again once you move off.
Post #40046 7th Sep 2010 11:01am
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
hey dgardel, your steering wheel is on the wrong side!!!! www.ralton.co.za
Post #40185 8th Sep 2010 4:05pm
harveyg77
Nah, he has put the negative in the wrong way Wink
Post #40188 8th Sep 2010 4:08pm
dgardel
Italy
Embarassed Embarassed Embarassed
Now I understand my difficulties when I want to pass other cars......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #40190 8th Sep 2010 4:42pm
dgardel
Italy
pouf wrote:
very nice dgardel,
IID Pro MV License
Post #40191 8th Sep 2010 4:45pm
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
Dgardel, how long is the sensor's wire?
Post #40209 8th Sep 2010 8:22pm
dgardel
Italy
Just the right lenght to arrive at the wing corner, no more ...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #40210 8th Sep 2010 9:18pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
What about a group buy
Post #40237 9th Sep 2010 7:02pm
holdingpoint
Yes, sound interesting! May be we can obtain a little discount!
Post #40246 9th Sep 2010 8:49pm
Page 1 of 4 1234>
