![]() | Home > Maintenance & Modifications > Outside temperature |
My Checktemp ( a mk 3) arrived today
![]() All thats left to do is translate the German instructions, I have a semi English set of instructions for the mk 2, and get it fitted. Hope it's not raining at the weekend ![]() Bob |
Hi Cranberry and welcome to def2.
The mk3 version has an outside and inside sensor plus connections to control the a/c, a bit like climate control I guess. There is an extremely helpful member in Venice who I am sure will be along at some point to answer your question ![]() Thanks for the offer of help in translation - if I get into trouble I will let you know. I do speak some German so that, coupled with the mk2 english instructions should see me through. Famous last words ![]() Bob |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I presume you don't have to connect to the aircon as some won't have it.
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Mine has turned up. Could do with English instructions
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 ![]() ![]() ![]() |
You mean like this one?
http://shop.conrad-uk.com/car/car-equipmen...57079.html Ordered one - It's £30 cheaper than Croytec! May be inferior but 30 quid's 30 quid...!
![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
Andrew If you can't work out the temp. connections they are Red - permanent 12v Black - earth Violet - switched 12v Yellow - Illumination Mines connected into the back of the radio - top tip from dgardel ![]() Mick You don't have to connect to a/c - I have not. Bob |
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Thanks Chaps
![]() ![]() ![]() Click image to enlarge 130's have feeling's as well you know ![]() |
Mine arrived today ordered on Sun not bad under that with this weather.
what are the blue and grey wires for going to a relay is that the aircon bit. ![]() |
Mick
Those are part of the Air Con set up. I am not using that so can't comment on exactly where they connect. Bob |
KPNuts Member Since: 21 Jan 2011 Location: Near Bedford Posts: 45 ![]() ![]() ![]() |
Has anyone got this instruction menu translated into English? Thanks Keith 2010 110 Utility Station Wagon 1996 110 Station Wagon |
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 265 ![]() ![]() ![]() |
just ordered my kit today. does any one have pictures of the the installation procedure? can do the wiring ok, but would like to see how the unit was mounted in the dash. Cheers
keith puer claudius |
