![]() | Home > Maintenance & Modifications > Outside temperature |
I have one of these
http://www.maplin.co.uk/Module.aspx?ModuleNo=34745 130's have feeling's as well you know ![]() |
holdingpoint Member Since: 18 Aug 2009 Location: Como Italy Posts: 35 ![]() ![]() ![]() |
Ok, well, thanks Andrew, but I though about something less invasive, and more "automotive". I have to ask to the dealer where the freelander's indicator is connected, and if is connected to the ECU.
Like mine?
![]() Click image to enlarge ![]() Click image to enlarge You can buy it here http://www.speedup.it/index.php?locale=en&...me.1131211 Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
very nice dgardel,
have you any photo with your outside sensor? tnks www.newfoundland.gr |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
http://cgi.ebay.co.uk/LCD-Digital-Thermome...925wt_1139
Any good?[/url] My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
shingwell Member Since: 13 Mar 2009 Location: herefordshire Posts: 45 ![]() ![]() |
The engine knows the air intake temperature, and a Scanguage can display this.
While you are moving it should be the same as the outside air temperature, although if you have been stationary with a hot engine there is little new air coming in and the reading rises, falling again once you move off. |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 ![]() ![]() ![]() |
hey dgardel, your steering wheel is on the wrong side!!!! www.ralton.co.za
harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309 ![]() ![]() |
Nah, he has put the negative in the wrong way ![]() |
![]() ![]() ![]() Now I understand my difficulties when I want to pass other cars......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 ![]() ![]() ![]() |
Dgardel, how long is the sensor's wire?
Just the right lenght to arrive at the wing corner, no more ...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
What about a group buy
Yes, sound interesting! May be we can obtain a little discount! |
