Home > Maintenance & Modifications > Outside temperature |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
mine came with English instructions
4th Feb 2011 5:21pm |
cabell Member Since: 20 Dec 2010 Location: Virginia, USA Posts: 33 |
For those who have installed the check temp.........Does the green backlighting match the factory dash and radio lighting pretty well? Does the backlight dim when the vehicle lights are switched on?
Oh, and can anyone tell me what the size of the outer bezel is? I think the cutout is 33.5 x 50, but I'm wondering what the finished dimension is. |
8th Feb 2011 10:04pm |
ext size 1"3/4 x1"1/8 dont know about the lights as not got round to fitting it yet .
8th Feb 2011 10:40pm |
KPNuts Member Since: 21 Jan 2011 Location: Near Bedford Posts: 45 |
Fitted mine on Monday. To my eyes, the green is pretty close to the LR green illumination. I would say it is a better match than the Phillips DAB stereo I have also fitted, and that has a choice of 3 greens! The backlight does dim when the vehicle lights are switched on (assuming that you connect the wire to the illumination on one of the other switches). I fitted mine on top of the dash using the supplied housing so it can be seen by driver and passenger. Looks quite good. Click image to enlarge The GPS mount does not hide it (despite how it appears in the photo). Keith 2010 110 Utility Station Wagon 1996 110 Station Wagon |
9th Feb 2011 10:28am |
Thanks for the replies guys. Where are you purchasing these? I can't find a source here in the US.
9th Feb 2011 2:18pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Mick, where'd you get yours?
9th Feb 2011 2:42pm |
I got mine from Conrad Electronic in the UK http://shop.conrad-uk.com/car/car-equipmen...54714.html but they only deliver to the UK. Their International arm (in Germany) says they do not deliver to the USA because of the insurance costs. Keith 2010 110 Utility Station Wagon 1996 110 Station Wagon |
9th Feb 2011 2:49pm |
Same place as Dg on page 1 of this thread took about 3 days to come fitted mine this aft not wired up yet, I got my cousin to make a picture frame stile template to make it easier to cut out. |
9th Feb 2011 6:05pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I've just fitted mine.
Instructions here Good piece of kit One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
9th Feb 2011 6:50pm |
jackl Member Since: 01 Apr 2015 Location: Northamptonshire Posts: 12 |
Afternoon all and I hope somebody can help me. I have just purchased a Check Temp time unit after reading some of the threads on the forum. I have never used any forum before but you all seem really helpful so thought I would give it a go. I have read through all the instructions, another new experience, one probably not to be repeated again... So my question do I need to install the relay shown and if so has anyone any more info. the unit has the following fused live (Red) Earth /Neutral (Black) Power from ignition (Purple) Power from lights (Yellow) ext temp sensor int temp sensor I then have a Grey, Blue and Orange to a Relay Blue (C) Grey (NC) Orange (NO) Do I need to use the last 3 if I am not connecting to the Air Con? Any help really appreciated. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
1st Apr 2015 11:59am |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Welcome Jackl.
If you are just using the standard Check Temp features (not the climate control stuff) you do not need the relay and you only need to connect the four wires you first mention and the sensors. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
1st Apr 2015 12:16pm |
Thanks Bob. Really appreciated. Time to cut a bit more of the dashboard away......
1st Apr 2015 2:13pm |
