Home > Maintenance & Modifications > Outside temperature |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
My Checktemp ( a mk 3) arrived today
All thats left to do is translate the German instructions, I have a semi English set of instructions for the mk 2, and get it fitted. Hope it's not raining at the weekend Bob |
28th Oct 2010 5:53pm |
Hi Cranberry and welcome to def2.
The mk3 version has an outside and inside sensor plus connections to control the a/c, a bit like climate control I guess. There is an extremely helpful member in Venice who I am sure will be along at some point to answer your question Thanks for the offer of help in translation - if I get into trouble I will let you know. I do speak some German so that, coupled with the mk2 english instructions should see me through. Famous last words Bob |
28th Oct 2010 6:25pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
I presume you don't have to connect to the aircon as some won't have it.
14th Dec 2010 10:36pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Mine has turned up. Could do with English instructions 130's have feeling's as well you know
14th Dec 2010 11:21pm |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 |
You mean like this one?
http://shop.conrad-uk.com/car/car-equipmen...57079.html Ordered one - It's £30 cheaper than Croytec! May be inferior but 30 quid's 30 quid...!
2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
15th Dec 2010 12:13am |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 |
15th Dec 2010 2:36pm |
Andrew If you can't work out the temp. connections they are Red - permanent 12v Black - earth Violet - switched 12v Yellow - Illumination Mines connected into the back of the radio - top tip from dgardel Mick You don't have to connect to a/c - I have not. Bob |
15th Dec 2010 9:00pm |
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
15th Dec 2010 9:07pm |
Thanks Chaps
Click image to enlarge 130's have feeling's as well you know |
15th Dec 2010 9:24pm |
Mine arrived today ordered on Sun not bad under that with this weather.
what are the blue and grey wires for going to a relay is that the aircon bit. |
22nd Dec 2010 7:24pm |
Mick
Those are part of the Air Con set up. I am not using that so can't comment on exactly where they connect. Bob |
22nd Dec 2010 7:50pm |
wont be usin.g them either thanks
22nd Dec 2010 7:56pm |
KPNuts Member Since: 21 Jan 2011 Location: Near Bedford Posts: 45 |
Has anyone got this instruction menu translated into English? Thanks Keith 2010 110 Utility Station Wagon 1996 110 Station Wagon |
3rd Feb 2011 5:33pm |
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 265 |
just ordered my kit today. does any one have pictures of the the installation procedure? can do the wiring ok, but would like to see how the unit was mounted in the dash. Cheers
keith puer claudius |
4th Feb 2011 10:06am |
