Home > Puma (Tdci) > TDCi Mpg's
Page 6 of 13 <123 ... 567 ... 111213>
jst
so 33" rims, add 10% to the mileage and that brings you upto 22mpg then? still bad though. i would have thought you should get 25/26 with a 110 and roof rack top speed 60 etc etc. TJ101 got that from his with a roof tent fitted.
Does yours do alot of idling or town driving? the ones i have used that idle alot or work alot using low down grunt seem to drink it for a fashion. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #5047 26th Nov 2008 7:27pm
The Boy
I drove to Birmingham (jun 2 M42) the other day on the stock tyres, I stuck to about 60mph all the way there and all the way back. I live 2 mile off the A45 and I went to a place 3 miles off jun 2 on the M42. I drove like a granny and had good traffic all the way. I filled the tank on the way out and refilled it when I got back. I got 23.2 mpg. my last 110 would have got 28/29 with the Brownschurch (with one piece 3mm alloy floor) on the roof if I had driven in that.
Post #5048 26th Nov 2008 7:37pm
jst
thats cr*p, i can understand why you are peeved. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #5049 26th Nov 2008 8:06pm
mse
that is bad. Mike
Post #5052 26th Nov 2008 8:33pm
chalky
definately bad !
i am doing a similar run on friday but across to Venture Overland in East Yorkshire. i will let you know what the MPG is after doing that but i can confirm that it is very economical ! compared to my other car an RS4 ! which thinks its related to Ollie Reed Bow down DEFENDER XS CSW 08 TONGA GREEN
Post #5060 26th Nov 2008 10:35pm
Caterham
Smile
555 miles on a tank full.
>27mpg - thats assuming I got 70 litres out of the tank which it was probably less, plus the 20 ltrs home brew.
when you consider a far amount of that is local pottering about and commuting into B'ham centre then having Miss Daisy in the back certainly appears to help compared to some of you with heavy boots and low mpg.
Post #5089 27th Nov 2008 10:02pm
jst
well first fill on mine, was showing over half full but Shell had 103.9 a litre so thought i would anyway. 29.69l for 167.4miles i make 25.6pmg which is ok for a 110 bedding in...... (i hope)
edited to add its better than the 2.8 TGV 90 auto which did 21mpg on the last fill! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #5185 1st Dec 2008 6:47pm
TJ101
But that was on a nice steady run round Spain and Portugal,, Patriot rack similar to your Boy !!
Mine has always been poor,, now on 8000 miles, most have been local running round, towing etc, and been in the 19 to 21 range,,
Even when JST has borrowed it, he could only get ?? what 21 ish ??
Did a trip to the Peak distract the other weekend, about 170 mile of lanes both on and off road etc, and 40 miles 70mph motorway, and returned just under the 25 overall,, its not moved since it was filled for the trip back,, all motorway, again at 70,, so will top up tonight and check again California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #5217 2nd Dec 2008 6:21pm
The Boy
Well mine brokedown agian tonight on the way home form work. Did what it always does (see my other posts) but I did get home at 15mph on "get you home mode". As this time i was running Petes tune I put the original one back on and when I restarted the car it was fine and the fault was cleared.
Post #5218 2nd Dec 2008 6:39pm
Caterham
365 miles and the light came on. another 20 miles and I'm putting 66 ltrs back in to fill up......
so what does that equate to......
26.5 mpg....not quite as good as my Citreon Picasso which managed 73mpg on one tank. Been running it on 100% bio diesel since and the economy has dropped but not nearly as much as the cost of the fuel.
Post #5441 11th Dec 2008 9:21pm
TJ101
Top it up,, 21.7 Shocked 70-75, no rack, add 255x85 Muds,, !!! hey-ho California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #5442 11th Dec 2008 10:34pm
jst
1si fill on mine 25.6mpg and second fill yesterday 28.1 (47L for 291 miles) vehicle is std with 500ish miles on it.
now what i dont get is why TJ101s is so bad when driven the same as mine about 5mpg difference there. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #5445 12th Dec 2008 8:37am
TJ101
Neither do I Shocked California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #5446 12th Dec 2008 9:04am
dave's 110
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Stornoway Grey
Been getting the same thing as you but my get me home mode is 30 mph when it dose this have you try pulling over switching off engine then after 30 sec start up again the engine light stays on but the fault is cleared so it will still drive to max speed
I also have a remap from Pete on the 3rd time of doing the fault. Set back to factory then waited till it done it again went to deals and got them to check it out found to be the fuel pressure valve got it done yesterday seems to run quieter know than before will give it a week then reinstall the remap and see how it runs
As for mpg averaging around the 27 but on long run motorway driving down to 24 mpg! best i have got is 29mpg would like to get 30 mpg then i would be happy as that's what my td5 did.
Dave
Post #5462 13th Dec 2008 1:22pm
gtveloce65
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Epsom Green
Dave - mine's very similar to yours - can't quite get to 30 on local trips and down to 25 on long m'way trips, especially if there's a headwind - it really does make a difference. So far, a bit worse than my old Td5 (30 and 27), which is disappointing, especially considering the difference in revs at 70mph.
I too have suffered from the engine going into crazed rattle mode. Always occurs during change-up whilst declutched. If you engage the clutch in time, it recovers. If you leave it to sort itself out, the yellow engine light comes on and you're in limp mode. Only happened to that degree once and I pulled over and restarted - yellow light still, but all running ok. Next time I started up, no yellow light, but the dealers were able to trace the fault and replaced the fuel pressure valve. I'd say it was slightly noisier after that and the problem's still there, so I'll keep you posted Mines in factory map at the moment. 1953 80
1965 Alfa Romeo GT Veloce Sprint
1980 Fiat 124 Spider
2008 110xs
Post #5528 15th Dec 2008 5:22pm
