![]() | Home > Maintenance & Modifications > Air box mod and decat |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Ahhh that will be it, hehe its been a long day and my brain is not working as fast as it should lol
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
Yep...that was it! ![]() ![]()
Plz post the "after" pics! Nice job! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
This looks good, however...... that pipework entry on the wing has no water sump / drain, anything entering is going straight down like a water shoot!
We all like a splash, and many go wading. I see my air box has drain holes in the bottom, but I've read some block those up. |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
Well the adaptor is now in the final stages of build. Ive decuded to leave making a frame to hold tge snorkel and just drill through the windscreen frame work as today I inspected my air filter and it was drenched! So the snorkel will be fitted theis weekend.
However! I am having trouble removing the air box to do the air box modding. It seems I need to drill six rivets in the inner arch but id like some confirmation bwfore I drill something that didnt need drilling, Pgotos will follow tomorrow after ive sprayed the adaptor |
For the air box mod cutting the inside out, you could just use a hot knife while the air box is in place which will save the need for its removal.
Regards Pete. |
Thats not a bad tip, given that I have air con and all my research is telling me to remove air con pipe or the inner arch, I may opt for the in situ idea, cheers,
I'm just fabricating another version of this (more later IF it works) - but I was a bit concerned about fatman saying:
"After the airbox mod,i think it lost some "sweetness" somewere between 1600 and 1800 rpm,definatly got noiser at 1800 rpm. " Before I take to the inside of the airbox with a Dremel, should I be worried? Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2668 ![]() ![]() ![]() |
I got my indie to do the airbox mod during the annual service last week. He also sealed up the pipe connections.
Can't say I can tell the difference though, but will watch the consumption -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Please could someone tell me where I can get the diaphragm thingy to fit under the air box valve in the middle of this photo:
[URL=] ![]() Click image to enlarge[/URL] I have no idea what it's called. Cheers Matt Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() But shout it at them in German because life is also terrifying and confusing... |
I dont think ive seen many with this actually fitted, ill keep my eyes out for you and see if I can get one.
Pete |
Thanks Pete - I had thought about just blocking it off but I'd still like the water to drain
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 ![]() ![]() ![]() |
I ment that i lost some of the gains i got from the hose replacement. Now i installed a bigger hose (102mm) and breathes right,we did the same thing to "Pouf's" stock puma http://www.defender2.net/forum/post308891.html#308891 and he also felt the gains,especially low down the rev range. |
Aaaah
andre.prum Member Since: 24 Feb 2014 Location: Bridel Posts: 8 ![]() ![]() ![]() |
I can't unfortunately see the picture added to your message.
Would you mind posting it again so that I can see how you modified the air box. Thanks in advance
