Home > Maintenance & Modifications > Air box mod and decat
Page 6 of 11 <123 ... 567 ... 91011>
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
Are you planning a 100mm intake tube like porny? Laughing
I think the more "radical"way is to open a hole on the opposite side of the filter box and let it breath through an opening next to the headlight,where the horn grill is now WRX style but then no more wading for the puma Confused
Post #301031 21st Jan 2014 9:31pm
theorangebandit
Haha yea I thought of the ram air style but that would simply become a ram water style. And yea something similar to porny but I plan to use a single plate design if I can suss it out
Post #301043 21st Jan 2014 9:46pm
Porny
Site Sponsor
102mm- the extra 2mm makes all the difference.
This is one of my original prototype set ups - I use a different pipe now - which has a smooth centre, and played around with the wing intake.
This fits onto a custom billet adaptor into the air box.
Ian
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #301046 21st Jan 2014 9:53pm
fatman
Mind when you step on it or you'll knock somebody unconcious,your def will suck all the available breathing air around it Thumbs Up Thumbs Up
Post #301050 21st Jan 2014 10:00pm
theorangebandit
Haha ill add the extra 2mm maybe ill go the extra and slide anoth 1mm on there so I have the biggest Whistle
Post #301056 21st Jan 2014 10:23pm
fatman
I guess you'll modify the inside of the airbox,i was thinking of doing that tomorrow but since i used a "tiny" 80mm tube-hose,it might be an overkill,i'll see..
Post #301060 21st Jan 2014 10:31pm
Porny
Site Sponsor
You will still get a good improvement with 80 mm hose and modifications to the air box. I started with 80 mm and only went larger when I wanted to step up further in power output.
Ian IRB
Post #301092 21st Jan 2014 11:39pm
fatman
First thing in the morning,i removed the inner restriction,i just used a blow torch and a hot knife.
The inner diameter of the "restrictor"-inner tube is 66mm and outside diameter 70.
Can't wait to test it..in 8 hours Crying or Very sad
Post #301130 22nd Jan 2014 9:42am
bell-auto-services
If anyone fancys lazer cutting some wing back plates we have a drawing you could use. in the .Rar file below is 80mm and 90mm PDF and .DXF files for what we prototyped with.
As said by Ian 102mm is best where possibile but is very hard to fit into a ABS car though not impossibile.
https://www.defender2.net/gallery/albums/u...0mm%20.rar
Pete
Post #301134 22nd Jan 2014 10:08am
fatman
And some feedback,although i drove only 30 kms of city traffic Sad
The biggest improvement was from the original piping replacement,i only have the puma for 5000 kms now and it was the first time i felt it like that especially in quite low revs.
After the airbox mod,i think it lost some "sweetness" somewere between 1600 and 1800 rpm,definatly got noiser at 1800 rpm.
I also feel that the more i drive it the more it adjusts to the changes i did - placebo effect strikes back Whistle
Thats what i saw-felt in my case,my def is far from stock configuration,hopefully i will try this mods to a mates stock puma the next 2 weeks.
So take a step each time.
Post #301418 23rd Jan 2014 7:48am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Pete
Embarassed stupid question...deleted....! Whistle Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #302846 28th Jan 2014 3:49pm
bell-auto-services
I dont understand, the file is still on the forum server for download its not been deleted.
Pete
Post #302857 28th Jan 2014 5:20pm
theorangebandit
The fabrication is taking shape slowly
Post #302960 28th Jan 2014 9:26pm
bell-auto-services
Looking good Thumbs Up
Post #302971 28th Jan 2014 9:44pm
I think he meant he'd deleted his own stupid question. Darren
Post #302991 28th Jan 2014 10:39pm
