![]() | Home > Maintenance & Modifications > Air box mod and decat |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
Haha yea I thought of the ram air style but that would simply become a ram water style. And yea something similar to porny but I plan to use a single plate design if I can suss it out
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 ![]() ![]() |
102mm- the extra 2mm makes all the difference.
This is one of my original prototype set ups - I use a different pipe now - which has a smooth centre, and played around with the wing intake. This fits onto a custom billet adaptor into the air box. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Ian Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 ![]() ![]() ![]() |
Mind when you step on it or you'll knock somebody unconcious,your def will suck all the available breathing air around it
Haha ill add the extra 2mm maybe ill go the extra and slide anoth 1mm on there so I have the biggest
I guess you'll modify the inside of the airbox,i was thinking of doing that tomorrow but since i used a "tiny" 80mm tube-hose,it might be an overkill,i'll see..
You will still get a good improvement with 80 mm hose and modifications to the air box. I started with 80 mm and only went larger when I wanted to step up further in power output.
Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
First thing in the morning,i removed the inner restriction,i just used a blow torch and a hot knife.
The inner diameter of the "restrictor"-inner tube is 66mm and outside diameter 70. Can't wait to test it..in 8 hours ![]() ![]() ![]() ![]() ![]() ![]() |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
If anyone fancys lazer cutting some wing back plates we have a drawing you could use. in the .Rar file below is 80mm and 90mm PDF and .DXF files for what we prototyped with.
As said by Ian 102mm is best where possibile but is very hard to fit into a ABS car though not impossibile. https://www.defender2.net/gallery/albums/u...0mm%20.rar ![]() Click image to enlarge ![]() Click image to enlarge Pete |
And some feedback,although i drove only 30 kms of city traffic
![]() The biggest improvement was from the original piping replacement,i only have the puma for 5000 kms now and it was the first time i felt it like that especially in quite low revs. After the airbox mod,i think it lost some "sweetness" somewere between 1600 and 1800 rpm,definatly got noiser at 1800 rpm. I also feel that the more i drive it the more it adjusts to the changes i did - placebo effect strikes back ![]() Thats what i saw-felt in my case,my def is far from stock configuration,hopefully i will try this mods to a mates stock puma the next 2 weeks. So take a step each time. |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 ![]() ![]() ![]() |
![]() ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
I dont understand, the file is still on the forum server for download its not been deleted.
Pete |
The fabrication is taking shape slowly
![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Looking good
I think he meant he'd deleted his own stupid question. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
