![]() | Home > My Defender > What Did You Do In Your Defender Today |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6133 ![]() ![]() ![]() |
Bought a years road rent for the 110.
![]() All that money for a 3" round piece of paper. |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
Removed the Webasto heater, replaced the faulty coolant pump with shiny new one and then slotted it all back together.
All working fine but now needs a new length of exhaust pipe because the old stainless one was split in several places - easy job to do later when the stuff I've just ordered arrives. Also experimented with Halfords (yeah I know) truck-bed liner paint on a hidden bit of the ARB winch bumper. If it looks good tomorrow morning I'll do the entire thing. It's already got three coats of POR-15 on it so this is just a top-coat. Dave Green Goddess - 1998 Defender 110 300tdi |
Splitpin Member Since: 07 May 2013 Location: Midlands Posts: 100 ![]() ![]() |
Shot blasted the door hinges and re-painted them.
The fitted the exmoor seat trim kit |
Well, not today, but a year ago today.. I went and picked up some new wheels and chequer plate. Strange how the day stuck in my mind? An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Defpuma Member Since: 10 Feb 2013 Location: Kent Posts: 84 ![]() ![]() ![]() |
Got up. Drove to work and parked the landie. Worked. Drove home! Via a couple of greenlanes!!
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
Any piccy's??? Russell 2011MY 110 XS USW Black |
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 ![]() ![]() ![]() |
Drove from near Lands End to Lincolnshire, stopped once for 20 mins, and took just over 9 hours
![]() ![]() Anyway several beers later and all is cured now ![]() ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5889 ![]() ![]() ![]() |
Here we go. Rear 50 amp Anderson connector with dust cap. Mounted to a bit of ally plate attached using the bolt that holds the rear tow bracket in place ![]() Kill switch inside the rear of the Defender mounted to the metal box that covers the rear wiring cluster. To be replaced by a relay and a switch on the dashboard at some point ![]() Click image to enlarge With boot to keep the dirt out. The wires will get some split tubing over them to stop them rubbing on the chassis. ![]() Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2119 ![]() ![]() ![]() |
.... been meaning to ask for ages .. how do you fit the towbar electrics in the hole in the rear cross member ...?
Is it a simple thing or is it mega fiddly and technical ...? (i.e. - could a non tech nursy type like me mangage to do it .....? ![]() (K9F will now probably produce thoushands of posts that I cant find !! ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
^^ LandRoverAnorak did a write up here...
http://defender2.net/forum/topic13747.html...+electrics An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Innuendomaster Member Since: 29 Mar 2013 Location: South East Posts: 230 ![]() ![]() |
I've fitted my Defender 3D rear Badge, fitted my D-Defender wheel arch spats, partially built the ICE shelf behind the rear Seats on the DC.
Still got to fit my New Kenwood head unit though, just building up the enthusiasm to tackle it ![]() |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
Not a good day! Set off to go to Chatsworth House and got just north of Coventry when my Alternator decided it didn't want to play anymore. Turned to head for home and on the way back the alternator managed to destory the serpentine belt. Lost all power steering and decided to admit defeat. Made the rest of the journey home on the back of a flatbed in shame.
Now just got to wait until Tuesday for a new belt and alternator from Adventure 4x4 to arrive. |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Same happened to my alternator recently ![]() ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Turned my fold down tailgate into a side opening one
