Page 345 of 1383 <123 ... 344345346 ... 138113821383>
dgardel
Italy
One relaxed weekend into the Alps (my father in love live in the Alleghe lake)....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #157364 22nd Jul 2012 8:42pm
GREENI wrote:
Today I drove 430 miles, half of that with the, 'ahem caravan cough' on tow Whistle
No need to be bashful, Greeni. It's not as if you're the only Land Rover owner to ever tow a caravan Rolling Eyes
By coincidence, I drove about 430 miles today too, delivering children to grand parents. Used the Freelander though, as it's a much better fast mile muncher Whistle
Got home and repaired the wiring to the rear NS door central locking that had decided to give up the ghost yesterday. Discovered that it had already been repaired once by the previous owner, badly Rolling Eyes All fixed now though and took the opportunity to repair a couple of trim anchors that had come adrift. Darren
Post #157365 22nd Jul 2012 8:42pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Looks nice there, might try a stop off on the way down to Venice in September :)
Post #157377 22nd Jul 2012 9:06pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Busy defender day (less children than normal)
Picked up snow cover and blanking plate from Zagato, well Mrs Zagato.
Fitted said snow cover:
Not sure if this is sitting a bit hogh with the grill and the chequer plate. Maybe the grill should be removed so the snow cover sits closer to the curve of the wing?
Fitted Entreq mudflap reinforcement brackets, courtesy of Leeds:
Even though I have done less than 5,000 miles from new, the panels were slightly deformed. I think this is an essential modification.
Fitted snorkel (and also blanking plate):
This needed some persuasion to fit. Has only been dry fitted for testing. Will need lots of gloop to get it to fit well and seal.
Fitted anti-theft bonnet hinges from ZeDefender:
Struggled to remove bonnet on my own (heavier than I thought). Bushes were such a tight fit and curls were so warped that I ended up with banana shaped bolts. No way this was going to fit by offering bonnet with hinges already attached to curls. Fitted hinges to body and got wife to hold bonnet against hinges while I attached bolts.
Post #157389 22nd Jul 2012 9:52pm
That, inigo, looks like a good day Cool
Post #157390 22nd Jul 2012 10:04pm
ZeDefender
I fitted my snow cover without the plastic grill but made a thinner aluminium mesh (diagonal mesh 10mm x 5mm) grill to replace it. Now the cover sits a bit lower down whilst still stopping bees etc coming through the air vents Laughing
The other reason is that last Winter (when I didn't have plate on the wings and the snow cover sat really low down on the plastic grill) I got the impression the heater blowers were struggling to get enough fresh air. The mesh has much less resistance. It's probably imaginary but it does seem better now.
Did you get the hinges on in the end? The differences between different Defenders' "designs" is worrying Rolling Eyes
Apparently, the order of fitting hinges to bonnet or curly first is very variable Sad Tell someone you love them today because life is short.
Post #157398 23rd Jul 2012 6:39am
Zagato
Looking good Inigo - sorry I missed you Thumbs Up
Post #157400 23rd Jul 2012 7:12am
pumaxs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Zambezi Silver
After only two weeks of ownership, sent it back to the Main Dealers to have a list of faults rectified. Sad
I will report back on my treatment via the Dealer Review section when hopefully all has been sorted. Neutral '57 Defender 110 XS Station Wagon 2.4tdci
Post #157439 23rd Jul 2012 1:10pm
JSG
Not a lot to report - been using mine and it has been faultless and getting dirty. Took it the local Polish hand wash chaps today so it now gleams.
Off to get the wheels sorted out tomorrow. I also need to find time to fit the new bonnet hinges ... John
2011 Tdci 110 CSW XS
Post #157510 23rd Jul 2012 6:00pm
dgardel
Italy
yobbie wrote:
Looks nice there, might try a stop off on the way down to Venice in September Smile
I'm waiting You :thumbsup:
IID Pro MV License
Post #157521 23rd Jul 2012 6:46pm
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
Changed the oil in both axles and transfer box.
Post #157671 24th Jul 2012 11:55am
JWL
Got round to taking off the last of the plastic bottom engine cover, it's been broken at the back where it fits to the centre cross member since about the second week of ownership three and a half years ago. Various sticks and lately cable ties are no not needed! Replaced a prop UJ at the rear as it was just starting to let go only trouble is, is that the spare I'd got hadn't got a greaser and I suspect the white box that it was in missed the part of the packaging process where they colour the boxes with blue crayons. Must get another proper spare in ready Rolling Eyes
Post #157709 24th Jul 2012 2:22pm
working on the wiring for the LEDS and Webasto .. getting there. Fuse box full now ... maybe I should have bought the 12 way version
Post #157801 24th Jul 2012 8:40pm
JSG
Had a nice drive to Fareham for some bling powder coating Thumbs Up John
Post #157812 24th Jul 2012 9:16pm
JWL
Put the eldest to bed by 7pm, he's finding it a tadge difficult to adjust to the school holidays with his autism so I went outside to get away from the "toddler whine" coming from the 15 year old upstairs Rolling Eyes Took the tie bar off the steering and made it straight again and replaced the track rod ends as the rubbers are starting to crack plus the new ones are greaseable. Was pleasantly surprised the ball joints came off with just a slap from the hammer and no need to put the Halfrauds special ball joint splitter to use. Just got to find that third balljoint that I bought yonks ago and do the other one whilst I'm at it Wink
Post #157824 24th Jul 2012 10:28pm
