Page 339 of 1382 <123 ... 338339340 ... 138013811382>
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
went to lower the tow ball to tow the caravan to Billing! Very Happy
from this
to this
btw nice paint job LR does to the rear crossmember hein? can you spot the diference? Neutral Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #155804 15th Jul 2012 9:19pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
my Betty, before the i stripped her down to rebuild..... Putting Dreams on Drives at JLR Solihull..
Post #155867 16th Jul 2012 10:17am
lrmaniac wrote:
Your tow bar is no longer held on with all of the bolts. Is that a good thing? Confused Darren
Post #155870 16th Jul 2012 10:21am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Well, a little while back, but my wife had another baby, so I've been a little busy.
Had a patriot rack fitted:
Quite pleased with it. It appears to be very well made. Slight whistling noise at certain speeds, if I have the radio off. Perhaps a slight decrease in mpg, but no discernible difference otherwise.
I visited the factory to have it fitted and a chat with Paul, who runs the company. I mentioned that I was dithering between his rack and the Hannibal and said the criticism of his racks that come up regularly are the corrosion of the bolts and the need to drill them out if anything needs to be changed. He said they now use Hylomar Blue to assemble which should mean that there is no longer any bi-metallic corrosion. I could just about see traces of it around some bolts:
The other thing he mentioned was that they have improved their powder coating and now use Keronite before powder coating. I had a quick look at their website: http://www.keronite.com and it seems to be some sort of ceramic coating. No idea how good this is in the real world, time will tell.
Post #155896 16th Jul 2012 12:24pm
Glynparry25
Used the ute to get into work........ Where I melted!!!
When leaning over the cables there was a constant dripping of sweat off my head (1 drop a second)....... Could be worse I could be cold and wet there in UK. I ended up finishing work 2 hours early because I was sweating out water faster than I could drink it.
The ute will be getting some much needed TLC in a couple of weeks.
Glyn Dog :sheep:
Post #155902 16th Jul 2012 1:01pm
lrmaniac
LandRoverAnorak wrote:
It's more stable to drive like this...although it has now only 4 bolts...but like it was it was easy to scratch the back of the caravan on the ground on a road bump or on the starting of a steeper rise...
I hope it's enough! Neutral Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #155903 16th Jul 2012 1:01pm
the 90: collected some waitrose rescue hens and a road-rock, sussex jobbie and some warrens, all at home now in their new coup .. went for a "Smiths Sectional" in the end
the 110: Fitted the National Luna power socket and tested Thumbs Up
Post #155956 16th Jul 2012 5:47pm
fekete
Nice coup....you will get some proper eggs now instead of them watery one from the supermarket Cool NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #155960 16th Jul 2012 5:58pm
Honker
 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
£460 lighter in the wallet due to first service Big Cry
Stu
Post #155961 16th Jul 2012 6:00pm
Fitted a 12v socket in the back using the spare purple and black wires:
The socket itself is taken from a Pajero, so will hopefully be boringly reliable Laughing
After filling up with fuel I also realised that yesterday was my first anniversary with this particular Land Rover. The anorak in me therefore feels the need to share this with the group:
I'm hoping that the MPG will pick up again when the Alive remap novelty has worn off a bit Whistle Darren
Post #156017 16th Jul 2012 9:11pm
excossack
Picked up 3 sheets of plaster board from Wickes.
Are those rear speaker housing standard LR ones or after market? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #156023 16th Jul 2012 9:15pm
Appleby
United Kingdom 2002 Defender 90 Td5 CSW Epsom Green
Very smart roof rack Inigo! Suits your landy a treat!
I got managed to perform the easiest mod so far. The 99 relay wiped mod. Perfect for the lovely summer we are having!
Post #156030 16th Jul 2012 9:21pm
They're the standard trim. Darren
Post #156033 16th Jul 2012 9:24pm
excossack
mmm not on mine they aint.,Sad (99' 110 SW) 1999 Defender TD5 110
Regards
John M0VAZ
Post #156039 16th Jul 2012 9:31pm
Mine's an '05. Perhaps they came in with the dash facelift in '02? They'd be a very easy retrofit if you can find some. Alternatively, the company that does the Defendoors also make a version HERE. Darren
Post #156045 16th Jul 2012 9:41pm
