Page 914 of 1380 <123 ... 913914915 ... 137813791380>
OlavLRD110
Estonia 2003 Defender 110 Td5 CSW Baltic Blue
Fixing door hinges.Press out 6mm pin and make new 8mm stainless steel pin.
Post #535065 27th May 2016 5:50am
agentmulder
Kuwait
Pulled off rear wheels, measured brake rotors and pads:
12.6mm RHS, 12.9mm LHS
7mm on the pads
Not too bad but weird that one rotor is wearing faster than the other.
Halfshafts and flanges have a bit of backlash, one side is welded together with corrosion, which is almost helpful - have put penetrating oil around the circlip for an overnight soak.
50/50 mix of ATF (auto transmission fluid) and acetone, apparently 60% better than the more costly Kano Kroil ... Solved the bowel problem, working on the consonants...
Post #535068 27th May 2016 6:27am
Have you successfully managed to remove the old pins, then?
Despite trying on many occasions, I have never yet been able successfully to remove the pin from a genuine original door hinge! What's your winning technique, if I might ask?
Post #535137 27th May 2016 11:36am
Huttopia
Took kids to school in the 90 pick up - some complaints starting about sitting 3 across the front, which I guess at 9 and 11 is a fair call. Bike to the bike shop for a fettle and then out for a ride for a couple of hours in the sun. Beer and BBQ beckons Very Happy
Post #535185 27th May 2016 3:32pm
agentmulder
Kuwait
Pulled off front wheels and gave the system a clean and inspect.
Front rotors: 21.6 straight on the LHS and 21.5 with a mean taper and wobble on the RHS
Pads 4-5mm
Time to swap.
LHS shaft corroded on to the flange - RHS appears brand new - interesting...
Put a wolf wheel on the rear to compare:
It's my spare... I like, but perhaps not enough to fork out for 4 more - what do you think? Solved the bowel problem, working on the consonants...
Post #535317 28th May 2016 4:44am
OlavLRD110
to blackwolf:
home made press:
Post #535397 28th May 2016 2:24pm
excossack
Two tip runs, one with a trailer full and a 8 600x600mm flags in the back
2nd run, no trailer but 6 bags full of rubble and a selection of broken bricks.
Jet washed underneath and removed some crud.
Rinsed, Washed, rinsed, left to dry and waxed half the 110. Cleaned the wheel arches with Autoglym bumper care. Look better now. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #535458 28th May 2016 6:24pm
@Olav.... Clever Thumbs Up
Post #535555 29th May 2016 6:22am
Wandathe110
Body off for a long hard slog
Post #535567 29th May 2016 7:23am
excossack
Wired in the rear speakers and finished waxing/polishing the 110. 1999 Defender TD5 110
Regards
John M0VAZ
Post #535610 29th May 2016 11:12am
A bit of polishing CP, found the stuff I used to be very good. Mr. Green
Post #535614 29th May 2016 11:50am
CarMan
Took 200tdi 3 up in the front to Prescott Hillclimb https://www.prescott-hillclimb.com/events/...talian-day
and saw some truly amazing machinery both old & new and parked it on a steep slope - just because I could Very Happy Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #535681 29th May 2016 4:54pm
OlavLRD110
Installed external side window protectors ( painted stainless steel )
Post #535707 29th May 2016 6:56pm
Carried on the puzzle of round hole/square peg.
Post #535711 29th May 2016 7:10pm
flyingfab
France 2015 Defender 90 Puma 2.2 XS CSW Indus Silver
I fitted (homemade) auxiliary power sockets in the back of my Landy, behind the cubby-box
Here's the story :
http://www.defender2.net/forum/post535769.html#535769
Wink
Post #535770 30th May 2016 1:10am
