OlavLRD110 Member Since: 03 Sep 2015 Location: Tallinn Posts: 20 ![]() ![]() ![]() |
Fixing door hinges.Press out 6mm pin and make new 8mm stainless steel pin.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17603 ![]() ![]() ![]() |
Have you successfully managed to remove the old pins, then? Despite trying on many occasions, I have never yet been able successfully to remove the pin from a genuine original door hinge! What's your winning technique, if I might ask? |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
Took kids to school in the 90 pick up - some complaints starting about sitting 3 across the front, which I guess at 9 and 11 is a fair call. Bike to the bike shop for a fettle and then out for a ride for a couple of hours in the sun. Beer and BBQ beckons
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Pulled off front wheels and gave the system a clean and inspect.
Front rotors: 21.6 straight on the LHS and 21.5 with a mean taper and wobble on the RHS Pads 4-5mm Time to swap. LHS shaft corroded on to the flange - RHS appears brand new - interesting... Put a wolf wheel on the rear to compare: ![]() Click image to enlarge It's my spare... I like, but perhaps not enough to fork out for 4 more - what do you think? Solved the bowel problem, working on the consonants... |
![]() Click image to enlarge to blackwolf: home made press: ![]() Click image to enlarge |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
Two tip runs, one with a trailer full and a 8 600x600mm flags in the back
2nd run, no trailer but 6 bags full of rubble and a selection of broken bricks. Jet washed underneath and removed some crud. Rinsed, Washed, rinsed, left to dry and waxed half the 110. Cleaned the wheel arches with Autoglym bumper care. Look better now. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
@Olav.... Clever
Wandathe110 Member Since: 10 Apr 2016 Location: Manchester Posts: 65 ![]() ![]() |
![]() Click image to enlarge Body off for a long hard slog |
Wired in the rear speakers and finished waxing/polishing the 110. 1999 Defender TD5 110
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20617 ![]() ![]() |
![]() Click image to enlarge A bit of polishing CP, found the stuff I used to be very good. ![]() |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1876 ![]() ![]() |
Took 200tdi 3 up in the front to Prescott Hillclimb https://www.prescott-hillclimb.com/events/...talian-day
and saw some truly amazing machinery both old & new and parked it on a steep slope - just because I could ![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
Installed external side window protectors ( painted stainless steel )
Carried on the puzzle of round hole/square peg.
flyingfab Member Since: 14 Jun 2015 Location: Brittany Posts: 60 ![]() ![]() ![]() |
I fitted (homemade) auxiliary power sockets in the back of my Landy, behind the cubby-box
![]() Here's the story : http://www.defender2.net/forum/post535769.html#535769 ![]() |
