Home > Maintenance & Modifications > Installing a aux power socket in the rear
Page 6 of 11 <123 ... 567 ... 91011>
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Thanks LRA Thumbs Up 2009 110 XS Station Wagon
Post #329239 8th May 2014 11:19am
Bear in mind that connector corrodes!
When I was fiddling with mine I pulled the fuse for safety's sake, much easier than disconnecting the battery.
I fitted a 2 pole Superseal connector on there so it's waterproof, rated at 14A I believe which is lower than the wiring and fuse but I'm never going to be using over that so suits ideally for me.
Surprising how damp it gets around there.
I think if you can get good connectors it makes these things look much better and a lot less DIY.
Is there a connector on the market that will fit the rear of the lighter socket too and not just have to use ins spades?
Post #329241 8th May 2014 11:35am
Oscar Romeo
Location: South Yorks, the pinnacle of all human achievement
England 2010 Defender 110 Puma 2.4 XS CSW Rimini Red
Just completed this this afternoon, socket of fleaBay for 2 of the queens pounds took for ever to come from china but is really quite good. Soldered the wires on, heat shrunk the connections and fitted a durite superseal connecter for no other reason than it came to hand first rummaging in my tech van.
30 mins or so later Boom Shocked new aux socket in the back!
Many thanks this forum for that idea and all who contributed to this tread Mr. Green
Post #330256 11th May 2014 4:25pm
timbar
Same here -- picked up a 20A rated socket and fitted it this morning. Found the config of the connector matched the spade connectors on the the socket I bought exactly, so no need for extensions. Magic. 2009 110 XS Station Wagon
Post #330297 11th May 2014 6:00pm
sat13
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
I fitted a power socket there about twelve months ago; it’s been a useful mod very handy for a work light. One thing I have noticed though is when using the socket with a plug with a tell tale led the led doesn’t light up; I only noticed this yesterday when working around that area and thought I would put my phone on to charge. The phone lead has a led light on it which did not come on. At first I thought there was a fault with the socket. As when I plugged the phone lead into the socket on the dash the led lights ok. Thinking the socket was faulty I was about to remove the trim but then I tried my work light and it worked ok. So the socket is working but using a plug with a led I get no light tried a couple of other plugs with same result. Anybody else noticed this; I know it doesn’t really matter as long as the socket works, but its bugging me not knowing why the led doesn’t light up. Could it be to do with the led needing an earth like some switches have? Don’t know, still trying to work it out. Any thoughts on this.
Regards to all Fletch.
Post #331772 18th May 2014 2:51pm
ericvv
^^ Did you connect the purple wire to the + of the socket? LEDs need to be wired correct polarity to function. Not sure about your socket, but on the one from Mudstuff which I used there is a + mark on one of the connectors. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #331778 18th May 2014 3:16pm
sat13
Yes purple to + it works fine just no tell tale led on the plug.
Post #331791 18th May 2014 4:37pm
sat13
SORTED, took off the trim to make sure about the orientation of the wires (purple to plus) ok but when looking further the + symbol was going to neg i.e. the body not the centre connection. Swapped the wires round and led lights ok now. Isn’t cheap Chinese stuff great, serves me right. Thanks for putting the idea about the polarity in my head. I just assumed that + would actually be + and would have took a lot longer to find an answer. I love this forum.
Fletch.
Post #331810 18th May 2014 5:54pm
Oscar Romeo
Lol thats top! Cant remember if i checked the polarity on my Chinese cheapie but I did notice while browsing round Craplins this week they had the exact same socket for 5 times the price! Rolling with laughter
Post #333233 24th May 2014 3:22pm
Caterham
great bit of useful info. thanks Thumbs Up
just wondering if anyone knows where to get replacement trim / clips - trip to LR?
will be pulling the trim off to do this mod along with some other 'stuff' I'm doing in that area.
Post #340445 24th Jun 2014 12:24pm
Dale
United Kingdom 2001 Defender 110 Td5 Tomb Raider LE Bonatti Grey
I've got a 2001 110 double cab and it also has the permanently live purple wire. However it is not wired into a t shaped socket with a black wire. It is just on its own with an insulated bullet style connector. Looks factory fitted connector as moulded to wire. There is also a black wire bundled with a green/black wire. The black one appears to be an earth. No idea on the other one. Also have two other unused sets of wires. I'm guessing only used on full hardtops. Maybe rear washer and wiper?
Post #345641 16th Jul 2014 8:25pm
Caterham
I need the memory of a goldfish as I believe they can remember things upto 3 seconds or so?
I measured the 12v outlet and found the right hole saw Re checked etc....picked up the arbour and then the hole saw.......
Picked up the wrong hole saw Big Cry now need new speaker surround......as I'm lining the drill up I'm thinking it's too big but thought stayed in brain and didn't transmit to finger - hence big hole.
Post #345648 16th Jul 2014 8:44pm
VeeTee
Netherlands
So you did not remember the old saying "measure thrice, cut once" ? Whistle Cheers, Vincent
MySite
Post #345650 16th Jul 2014 8:56pm
Caterham
I did. Measured it several times etc but after doing that I then managed to pick up the wrong tool (hole saw) and went straight onto auto pilot!?
Any recommendations on where to get replacement asap?
Post #345657 16th Jul 2014 9:05pm
munch90
oh dear , don't worry we all done it at sometime , one of those 'oh bo!!ocks ' moments
glue a flat piece of plastic on the back over the hole then cut RIGHT size hole and when the socket is fitted doubt you would notice the mistake
you may find that recovering from your mistake and not just buying a new part will give you better satisfaction ! , when the job turns out ok
Post #345662 16th Jul 2014 9:18pm
