Home > Maintenance & Modifications > Installing a aux power socket in the rear
Page 11 of 11 <123 ... 91011
nitram17
i agree there are some great threads that are so frustrating because the pictures are gone!there are not that many sticky threads though i was just wondering if martin could find a way to keep the pictures on the sticky threads intact?
Post #965905 24th Sep 2022 7:19pm
I don't think the forum works like that, to be honest, but you could always ask Martin. Darren
Post #965917 24th Sep 2022 7:58pm
nitram17
There must be a way for the administrator to copy a small number of threads/pictures and host them on the site and protect them From Im sure martin will eventually see this and help if he can!
Post #965921 24th Sep 2022 8:31pm
Berni99
Really helpful info on this thread guys. Thanks! Very Happy Very Happy Very Happy
Post #978392 16th Jan 2023 6:20pm
InternationalDBA
United Kingdom 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Black wire and purple wire with a connector at the end
I am fitting a new chassis to my 2008 Defender.
I refitted the loom in the chassis and wired up the NSR lights with no problem.
However, on the OSR there is an extra connector at the end of 2 wires, one black and one purple.
They are substantial wires and could perhaps take 20 amps as suggested in the post.
I spent all afternoon trying to work out where to plug in the connector without success.
The connector is under the speaker as suggested so I guess I can just ignore it.
It's a shame that I cannot see the original pictures to confirm we are describing the same issue.
Post #1031369 12th Apr 2024 5:22pm
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Hi,
Apologies, but what number is the fuse located for this?
I’ve had a very quick breeze through, but am really short of time.
With thanks
Post #1042374 10th Aug 2024 7:34am
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
Fuse 2 Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1042456 10th Aug 2024 11:03pm
Cragster69
Bought a charging point with a view at installing an aux socket over the weekend
I have the black and purple wires in a plug
Before I break out the hole saw I thought I'd check the electrics, no volts across the plug, found Fuse 2 blown and replaced. But still nothing, tried with the ignition on (thought it was a permanent live) just to see if that would solve the problem.
Any suggestions on what else to check?
I don't seem to be getting any supply to the heated rear window either, but that's a different fuse and was intact. Craig.
www.scotgrc.co.uk
Post #1057694 17th Jan 2025 8:03pm
Cragster69
Pulled Fuse 2 again still intact put it back in and checked the voltage 12V now registering.
Cut 3 holes in the trim
Plate and sockets fitted and connected
 Craig.
www.scotgrc.co.uk
Post #1059167 1st Feb 2025 10:56am
macfrank
Thumbs Up
Post #1059342 3rd Feb 2025 6:08am
