Home > Maintenance & Modifications > Installing a aux power socket in the rear
Page 4 of 11 <123 45 ... 91011>
mobilecentre wrote:
The whole wire has not been deleted just the two way connector that goes "nowhere" has been removed from the loom the cable still continues from Fuse 2 under the seat through to the rear loom and terminates in the towing electrics connector in the rear wheel arch.
OK we are talking MY13 now (not earlier models) - I thought the rear loom for the towing electrics was a separate stand alone loom that has to be purchased as an accessory and is usually routed directly from the socket to the front passenger's underseat box?
I have towing electics fitted and no multiplug behind the rear speaker covers.
Post #250381 10th Jul 2013 6:33am
The additional towing electrics loom connects, in general terms, in two different places depending on type. The 12N loom, i.e. standard 7 pin lights only, connects to a multiplug under the rear OS wheel arch directly under the speaker cover. The 12S loom for the 7 pin caravan supplementary socket runs forward to the under seat battery box. The 13 pin loom, which combines both of the '12' types, connects in both places.
The multiplug behind the speaker cover is a spur from the vehicle-side towing electrics loom and exists, or existed, on all vehicles regardless of whether towing sockets were fitted. It appears to have been deleted from MY13 though. Darren
Post #250384 10th Jul 2013 6:42am
Martin 01
Checked it all out with multi meter & no power at black & purple plug.
All fuses seem to be fine.
Can't see any in line fuses, may have to investigate further.
I can't believe it's just not a fuse in the box.
Got me baffled.
Any suggestions ?
Thumbs Up
Post #250393 10th Jul 2013 7:22am
This supply is permanent live so it's not a complicated circuit. If the fuse is ok then there's a fault somewhere and the only solution is methodically checking. Is power getting to the fuse, for example? Darren
Post #250405 10th Jul 2013 8:26am
Martin 01
Darren,
Yes power to the fuse as the towing electrics are working.
Unless its a different fuse, but all fuses are ok.
Martin
Post #250423 10th Jul 2013 9:47am
DiscoStu wrote:
Thank you Thumbs Up
DiscoStu - not for a MY13 - at least not for mine. I only have a connection for the rear lights:
Post #250425 10th Jul 2013 9:49am
As I said earlier, the spur from the vehicle-side towing electrics loom has been deleted from MY13. However, as Tim said, the towing electrics loom itself is still in place in the wheel arch directly below the area shown in your first picture, so it can be picked up from there without too much trouble. It's no longer plug-n-play, though. Darren
Post #250431 10th Jul 2013 10:11am
Martin 01
All sorted now guys.
Thanks for all the info.
Got auto electrician to take a look & he sussed it.
At some time someone has wired in a separate switch & relay which is where the problem was.
Now connected back to original wires & all is working.
Now means cool beers in the fridge in the back.
Thumbs Up
Post #250532 10th Jul 2013 4:52pm
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
Supacat wrote:
DiscoStu wrote:
Thank you Thumbs Up
Cheers, noticed that Thumbs Up
For MY13 (110 XS SW)
Rear of rear wheel arch, drivers side. There's a black plastic cover over the wiring
Cover removed,
Loose plug with purple wire is hanging behind the cover,
 My Disco 'best bits'
Defender 110 XS CSW 2013
Post #250874 12th Jul 2013 10:19am
yesterday I installed a 12v socket inside the glovebox and connected to the 12v socket on the dash centre, nice out of the way place to charge stuff or run the satnav without having cables near the gearstick.
Post #250887 12th Jul 2013 11:52am
That's the multiplug connector for the towing electrics. They all have one of those. Darren
Post #250888 12th Jul 2013 12:18pm
DiscoStu
Yes, but on a MY13 that's where you need to go back to to get the purple 12v feed. My Disco 'best bits'
Post #250896 12th Jul 2013 1:29pm
Sorry, I've misunderstood what you were trying to say. Darren
Post #250903 12th Jul 2013 2:21pm
DiscoStu
Thumbs Up No worries My Disco 'best bits'
Post #250904 12th Jul 2013 2:32pm
mobilecentre
mobilecentre wrote:
Purple wire can be seen on right hand side of plug
This is a MY2012 vehicle
Post #251097 13th Jul 2013 5:45pm
