Home > Puma (Tdci) > 2 stroke oil adding
johnnyturbo2002
Spain 2008 Defender 110 Puma 2.4 CSW Java Black
2 stroke oil adding
Hi,
Are the majority of you guys still using and if so/not any adverse effects?
Regular two stroke right? The kind for chainsaws and such?
Tanks a bunch!
Jt 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey!
2008 Kia Sorento LX 😁 2.5crdi
Post #210661 12th Feb 2013 10:53am
ericvv
Why the question? Have you engine problems which you think may be resolved by using 2SO? I have never used 2SO in my Puma, and never had any problems, but can tell you that when I switched away from supermarket fuels to using almost exclusively BP Ultimate Diesel, the engine runs much, much smoother Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #210663 12th Feb 2013 11:00am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
.......... 250/300 Cl of 2 stroke oil "Jaso FC " on every full fuel .
http://www.defender2.net/forum/topic9189.h...oil+adding
http://www.africaland.it/forum/viewtopic.p...fe16d0bb7e
Wink Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #210668 12th Feb 2013 11:36am
johnnyturbo2002
Eric,
No reason really, just in winter, because of fuel differences, it sounds a bit different...still runs super,
Cheers, 2008 Defender 110 60 year Edition (sold unfortunately)
Post #210701 12th Feb 2013 2:30pm
ZeDefender
Aral (BP) fuel here is okay but 250ml of Actevo every other tank quietens my Puma engine in winter.
Some members have been using it for years with no adverse effects, so it's safe to try it out and decide yourself Thumbs Up Tell someone you love them today because life is short.
Post #210702 12th Feb 2013 2:43pm
ericvv
johnnyturbo2002 wrote:
Eric,
Cheers,
What fuel do you normally use?
Post #210703 12th Feb 2013 2:44pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Jaso FB... I read....and use.... Question Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #210705 12th Feb 2013 3:05pm
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
I used to put in 2SO (Td5, not Puma) but in all honesty couldn't really tell much, (if any) difference to not putting any in. However, I have found a noticeable difference using Millers Eco Max additive though, both in quietness of the engine and performance. It's more expensive to buy than 2SO (roughly twice the price) but with a mix ratio of 1:1000 as opposed to 1:200 probably works out cheaper. Doesn't answer your question on 2SO I know, but worth considering as an alternative.
Post #210709 12th Feb 2013 3:19pm
pannawonica
Australia
I have used 2SO FC ( Mineral) now for 25K miles. I have found that it make the engine sound more refined. I have heard that the reduction in sulfur 5o ppm and the loss of its lubrication properties has caused premature fuel pump failure. Diesel is oil and 2SO is just a more refined product with anti carbon deposit properties.
Post #210862 13th Feb 2013 5:15am
bvandyk
Does adding 2 stroke oil not increase the sulphur content of the diesel, and because of that reduces your service interval?
Post #210941 13th Feb 2013 3:16pm
sven
Norway 2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Have tried adding 2-stroke oil over a period and theres no change whatsoever in engine noise. Bow down 2009 Land Rover Defender 90 SVX Soft top 60th Anniversary Edition
Post #211047 13th Feb 2013 9:51pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I bought a bottle of the Millers additive yesterday.... Too soon to say if it makes any difference, but, hey, no harm trying!
I did try 2SO about 18 months back, and I think my engine was too tight to notice any difference, plus it wasn't BAS'd!! 37K and a remap may make things more obvious.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #211084 13th Feb 2013 11:21pm
bvandyk
On my previous Defender, a TD5 with 250000km on at that stage it made a massive difference. The engine was a lot smoother.
Now on my Puma with 40000km on when I first tried it, I could feel and hear absolutely no difference.
So I think a lot of it got to do with the condition and age of the engine. But it's not all about feeling and hearing a difference. It's about getting everything more reliable in the long term.
That being said, I don't add 2SO to every tank on the Puma anymore. About every 4th tank. On the TD5 I used it with every single tank.
Post #211111 14th Feb 2013 7:22am
Naks
I use it on every 2nd tank on my Puma, it runs a bit smoother, and the most telling sign is that the EGR is squeaky clean --
Post #211114 14th Feb 2013 8:15am
robharvey
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
Oddly enough the only time I added 2so my EGR went for a ball and had to be replaced. My new EGR is squeaky clean running without 2so for the last 60k.
Post #211122 14th Feb 2013 9:04am
