Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
Collected the a bar today and gave it a clean to see what I've ended up with
Click image to enlarge Not too bad over all, apart from the attempt at a repair someone has done Couldn't resist finding out what it looks like on I'm a bit pooped after the seven hour round trip so it'll probably stay on until I have time to sort out the bodge. Click image to enlarge Thanks for looking. Ray My build thread http://www.defender2.net/forum/topic17615.html |
22nd May 2015 7:30pm |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 714 |
Much better!!! What did you clean it with?
22nd May 2015 8:30pm |
The ULTIMATE cleaner!!! Baby wipes then autoglym bumper care, brings it up a treat, almost looked new again Ray
22nd May 2015 9:00pm |
Mine were Corsetti but they stopped making but same supplier same style, badged differently....
http://www.defender2.net/forum/post412075.html#412075 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
22nd May 2015 9:51pm |
takoon Member Since: 16 Oct 2013 Location: central Posts: 48 |
Click image to enlarge Are they the same as 4most4x4 .com has in their shop? Looks better that those I have at the moment. -99 Td5 90 CSW -09 Jaguar xk4,2 Portfolio |
23rd May 2015 2:05pm |
No they're not! Read my previous post on where to source them! Apologies for the thread going off piste Ray. I can delete if you wish! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
23rd May 2015 6:27pm |
No worries Ray
23rd May 2015 6:34pm |
A few more things turned up this week. After being let down buy three company's trying to get a full rear anti roll bar fitting kit for the past few months I decided to just order all the bits separately which was a few s more but at least all the bits would be there and not promised but nothing turns up for a couple of weeks only to be told again that it's out of stock
So I'm finally going to get the rear anti roll bar fitted in the next couple of days!!! The service is due in a week or two so all the oils turned up from opie and the gen filters, while the service is getting done the transfer box is getting dropped as I haven't been able to stop the oil drip so I've got a full seal kit for that too ( hopefully no more oily drive!!!) the last time the 110 was in the garage it had a new a frame ball joint fitted but I forgot to get new bolt and the mech said they weren't in the best condition so I've got a couple of new ones to go on while its in too. I also ended up buying a new ariel as when fitting the one I bought off a forum member last week I over tightened the top and snapped it And last but not least, I found some brand new bottom brackets for my (new to me) a bar on eBay listed as the wrong part so won them for 99p I'll get a pair of the stronger Ali brackets for the top so when its repaired it should all look like new again. Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
7th Jun 2015 10:44am |
Look what turned up today it means I don't have to repair the other one, just need some time to put it on now.
8th Jun 2015 2:13pm |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 |
How much would you want for the other one? How bad is the damage? Tom
@tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
8th Jun 2015 3:22pm |
^^^^ pm'd. Got the anti roll bar fitted and raised the rear mud flaps so no more scraping on the floor up and down the hills around here Ray
9th Jun 2015 9:46am |
She got a full service yesterday and all the seals replaced on the transfer box because I couldn't stop the leak while the box was attached, so no more oil on the drive also got fed up of the rattely rear door handle (after 11 years hammer) so decided to replace it with land rovers new lightweight version
Click image to enlarge What was the point with the extra holes? Ray My build thread http://www.defender2.net/forum/topic17615.html |
20th Jun 2015 11:33am |
^^ Fuel economy! If you go through life with your head in the sand....all people will see is an ar5e!!
20th Jun 2015 11:37am |
I'm aiming for caterhams Magic 600!!! Only got to find another 260 miles a tank Ray
20th Jun 2015 11:46am |
