Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
Some more bits arrived today.
Click image to enlarge I'll see how long the hinges stay tight and if they don't last I'll get some of the orp ones. The old door waist seals were past their best Click image to enlarge The new ones were described as oem but aren't exactly the same and needed some trimming here and there to fit but it looks tidier than before Thanks for looking, all comments welcome. Ray My build thread http://www.defender2.net/forum/topic17615.html |
7th May 2015 1:36pm |
I went for the YRM Safari Door Hinges as the ORP ones were a little too far off OEM. Three letter abreviations don't you just love 'em?
Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th May 2015 1:45pm |
I just don't like the setup of the original hinges as they just seem too easy to wear out but with the wheel carrier now taking the weight of the spare I hopefully won't have the sagging problem anymore and maybe not on the car door either
Edit: I'd have to get the orp ones painted if I got them so they didn't stick out as much. Ray My build thread http://www.defender2.net/forum/topic17615.html |
7th May 2015 1:55pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 |
Where did you find the window rubbers as need to get 2 new back ones for mine.
Like the updates, got a few ideas I'll have a go at from this thread. |
7th May 2015 3:43pm |
the seals came from Sp-4x4 this should hopefully be a link for one side and the other side is on their site too.
http://www.sp-4x4.com/DEFENDER_110_DOOR_SE...lr5982.htm Ray My build thread http://www.defender2.net/forum/topic17615.html |
7th May 2015 4:04pm |
Fitted the new hinges and the stainless nakatanenga bolts today.
Click image to enlarge I knew the old hinges were shot but putting the new ones on lifted the door about 1/2 an inch but at least the door shouldn't hit the lower crossmember bit anymore now!!! Old rusty worn out ones even after I fitted new bolts and brass inserts last year Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
13th May 2015 2:28pm |
Big thanks to buckblu110 for pointing this out on ebay
Poor eBay pic. I've been looking for one for the last few years after seeing tj101's 110 on here as I love the look but the wrap around ones never seem to come up for sale. It needs a bit of repair but I got it for a good price so just a 6 hour round trip to pick it up on Friday and then a bit of work fixing Ray My build thread http://www.defender2.net/forum/topic17615.html |
18th May 2015 9:18am |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 714 |
18th May 2015 1:14pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
Great find. They do look great. What is the damage it has sustained? 2002 110 td5
18th May 2015 8:51pm |
There was only one small pic of the damage but it looked like a couple of cracks on the top that had had some plastic filler poorly put in then not rubbed down hopefully not too bad to sort out but I got it at a very good price so should be sortable. Ray
18th May 2015 9:31pm |
With the spacers came the usual muck thrown up the sides so I popped over to mud this afternoon to pick these up
Click image to enlarge Just getting them painted and I'll get them fitted in the next couple of days Ray My build thread http://www.defender2.net/forum/topic17615.html |
20th May 2015 2:51pm |
Hopefully no more mud up the side
Click image to enlarge Just waiting for some bolts too arrive then I can raise the rear mud flaps a couple of inch which should also help Ray My build thread http://www.defender2.net/forum/topic17615.html |
21st May 2015 3:04pm |
Raise the flaps Ray or move them out? I moved mine out to prevent muck spray about 1-2"
And no that isn't a midget in my passenger seat. Damn cyclists..... Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
21st May 2015 4:03pm |
I thought the midget was wearing a helmet because of your driving I might move the mud flaps out a little too but the moving up was because I lowered the back by about 2 inch and they catch when turning up and down all the steep hills around here. Should keep mud splatter down too though so a bit of a bonus Ray
21st May 2015 4:14pm |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 329 |
Light force spots, soo much better to look at than an LED light bar !
22nd May 2015 4:54pm |
