Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 13 of 81 <123 ... 121314 ... 798081>
mk1collector
Sounds good to me Thumbs Up I gave up work to look after the kids about 9 years ago. It's not all been easy but it's better than working on other peoples cars Mr. Green
Post #362096 4th Oct 2014 7:56am
Tiger
How hard were the rear windows to fit and where did you get them from?
Post #363093 8th Oct 2014 12:08pm
mk1collector
The sliders and middle row were from masai. The sliders needed one corner of the appature filing out as the factory windows had less of a curve on one corner for some reason Rolling Eyes but overall not really a hard job, just time consuming. Make sure you buy some capped rivets before fitting though as the ones that came with the windows were open ones so would let water in. The middle row were a lot more of a pain because the mounts at the bottom of the wind down window need sticking on with proper window primer and sealant (luckily my mate is a window fitter) and you need to make sure they are in exactly the right place.
Post #363112 8th Oct 2014 3:40pm
Tiger
So would recommend them both or save up and get Landyglass?
Are they decent quality?
Post #363128 8th Oct 2014 5:11pm
mk1collector
If you don't mind the work I would recommend them as the quality is good and the tint is not too dark, but have everything ready to do the job before you start or its a pita
Post #363183 8th Oct 2014 7:25pm
mk1collector
Couple of bits turned up yesterday so I just need some dry weather now Rolling Eyes
Post #364326 14th Oct 2014 8:19am
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Fun times crawling on your back Whistle
Let me know your verdict on the hydrate 80. 2002 110 td5
Post #364432 14th Oct 2014 4:04pm
mk1collector
Yes, not looking forward to crawling round underneath Big Cry I went for hydrate 80 because I saw your rear crossmember refurb post Thumbs Up I'll post up how it goes.
I've already fitted the cps which seems too have sorted a slight hunting on idle I had, but I've only been for a short drive so,don't know if it's just a coincidence. The old cps did look rough though and didn't have the spacer!
Ray
Post #364463 14th Oct 2014 6:02pm
mk1collector
Big Cry just been to the garage as my rattle sounded quite noisy today (it's been intermittent) and my fears were confirmed, or at least they thought the same as me. The couple year old DMF seems to be on its way out Big Cry I see a big bill coming my way Sad
Post #364984 16th Oct 2014 4:36pm
mk1collector
Won some new genuine washer jets on ebay the other day, so I picked up some washer tube and a t peice from halfords over the weekend. I just need a bit of dry weather now to do the two washer mod and I'll hopefully have clear windows this winter Mr. Green also started hydrate 80ing the back third of the chassis and will add some dinitrol tomorrow. The warm weather has helped me out as I didn't think I'd still have time this year. Checked out the internals of my disco transfer box too today and they look pretty clean so I'll stick two output seals in (just in case) and throw it on while the DMF is getting done this week and hope that it's a good un Rolling with laughter
Ray
Post #365791 19th Oct 2014 10:34pm
Tiger
Beat you to the washer mod Thumbs Up did it 2 weeks ago.
The hole is an oval, I used 2 tap washers to cover the hole and seal it.
Post #365792 19th Oct 2014 10:42pm
mk1collector
Rolling with laughter well come on then stick some pics up so I know what to do Rolling with laughter
Post #365793 19th Oct 2014 10:47pm
Tiger
Didn't photo it
http://www.defender2.net/forum/post363091.html#363091
But can be seen in this photo, dead easy, just need a T piece about 2 foot of extra tube and some 1" rubber tap washers and a rubber grommet to fill old hole. Thumbs Up
Post #365794 19th Oct 2014 10:54pm
mk1collector
Looks like it's a trip to b and q tomorrow for some washers then Thumbs Up I still need to wire up my heated screen too while the dash is apart, it's only been in a year Rolling with laughter
Post #365796 19th Oct 2014 11:00pm
Tiger
Did that last week Whistle
Post #365797 19th Oct 2014 11:04pm
